Old 06-30-2012, 01:41 AM
Ngtflyr Ngtflyr is offline
Default Fan Belts 69 Chevelle L78
Anyone have the fan belt lengths or part numbers for a 69 Chevelle(el Camino) L78 with smog, manual steering, stock pulleys.
TIA
Dave
Old 06-30-2012, 12:12 PM
Default Re: Fan Belts 69 Chevelle L78
Manual steering isn't a factor.
The correct A.I.R. fan belt measures 3/8" wide X 47-1/2" long and was coded YE in box #37 of the buildsheet.
The original 1969 Chevrolet Chevelle/Elco L-78 part number is 3921934. http://www.gastanks.com/1969-Chevell...nfo/29-B-589B/
The original 1970 Chevrolet Chevelle/Elco L-78 part number is 3883248.http://www.gastanks.com/1970-Chevell...info/29-B-603/
Quanta is very good,but can be a lil confusing @ times.
I recommend calling them first & asking the actual part# stamped into the belt & dimensions of the belt you want before ordering.
Old 07-03-2012, 03:52 PM
Rick,
Thanks for the links.
As for Quanta, I've heard about issues with thier belts stretching and as a result slipping with any use. What's your take on this issue? Or, is it even an issue, I have no first hand knowledge just 3rd hand info.
Dave
Old 07-03-2012, 04:56 PM
I use Quanta belts on EVERY restoration and have had absolutely no issues with them in the past. However, keep in mind most of these cars see limited street use.
Old 07-04-2012, 02:22 AM
Don_Lightfoot's Avatar
Don_Lightfoot Don_Lightfoot is offline
I agree with Rick Nelson as far as appearance, but I had nothing but problems with some I have used in the past on two different cars. If you plan to have some <span style="font-weight: bold">&quot;occasional&quot;</span> fun with your car (EG - heavy foot), watch out for twisting and/or flying off rendering your water pump inoperative which hopefully you will catch in time. Deep groove pulleys help though they are not the ultimatie preventative. For show - yes, for driving - no. My car only sees about 200 miles a year, but I will not risk using those belts.
Just my very humble opinion.
Specialized Chevrolet Decals
Old 07-04-2012, 02:26 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SS427</div><div class="ubbcode-body">I use Quanta belts on EVERY restoration and have had absolutely no issues with them in the past. However, keep in mind most of these cars see limited street use. </div></div>
X2, No issues what so ever. They make a Great product. I will be testing there product on the track at this years SCR15.
Old 07-04-2012, 03:18 AM
XXXGoldL34M20's Avatar
I also have the Quanta belt running my Smog/Water Pump+Main on my LS6 [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
