Old 06-08-2012, 03:51 AM
Default 69 L88 427 Engine 3963512 All Parts NO RESERVE!
I just parted out a 69 L88 427 out of a boat. It is a closed chamber L88 that came with cast iron heads since it was a boat. I decided to part it out the engine since many of the parts don't jive with eachother from a restoration standpoint but all are applicable to muscle car restorations. Here are some of the auctions that may interest you guys:
3919840 Rectangular Port Heads
3856284 Big Block Short Water Pump
L88 Fuel Pump
396 427 454 8 Inch "AOR" Timing Cover
Big Block OEM Pushrods
Big Block Oil Pan Mounting Bolts
Big Block Original Head Bolt Set
Big Block High Lift "L" Rocker Set
8 Inch 396 427 Balancer
3933198 L88 & Zl1 Aluminum Intake
Big Block Chevy Aluminum Intake Mounting Bolt Set
Big Block Chevy Timing Cover Mounting Bolt Set
And Finally......
69 L88 427 Shortblock
Thanks and Good Luck,
