Old 06-08-2012, 01:07 AM
subyman99 subyman99 is offline
Default 69 z28 302 running hot on hwy
Hi, i just took my 69 z out for a ride tonight, was gonna hit up a cruise that was about 60 miles from town, ive never really got the z out to stretch her legs but has always been great around town. Soon as i hit the hwy the temp climbed to 205 degrees at around 60 mph, the faster i went the higher the temp. Everything is original and stock on the car. Any ideas? the engine has been rebuilt, with all stock oem parts. Thanks
Matt
1967 Z28 survivor Black original drivetrain
1968 Z28 survivor white 40k miles
1969 Z28 survivor Rally Green 60k miles
1969 Z28 survivor Rally Green 20k miles
1969 Yenko Camaro Lemans Blue -muscatell sold new, second to last yenko made
1969 Berger copo original paint 240 miles
Lots of 67-72 Chevrolet trucks
Old 06-08-2012, 01:10 AM
Default Re: 69 z28 302 running hot on hwy
sure it was a true 205 degrees? Did it smell, boil over, lose some power etc? NO water pump leaks, lose fan belt, bad clutch fan? Hows the radiator situation? Try some of that water wetter solution. 180 is OK in my book.
Old 06-08-2012, 01:13 AM
ive got a aftermarket mechanical gauge, since my factory one was reading hot, my aftermarket gauge was showing all of 205, no boiling over, exept for the a few drips of coolant from overflow. I want to see 180... Imo its running to hot
1969z280 1969z280 is offline
The fan clutch sounds like a likely culprit. Once the engine is hot, turn it off and if the fan still spins, it's the clutch.
... some old Chevrolets and Pontiacs.
Old 06-08-2012, 01:22 AM
process of elimination I guess Matt. Could be the fan clutch but if it was running cool around town it would probably have acted up there also. Hows your rad. cap?
Old 06-08-2012, 02:04 AM
BARRY BARRY is offline
Yenko Advertising Member
how warm out side is when this happened
Barry Allan
Old 06-08-2012, 02:05 AM
ive tried 2 rc15 caps and one aftermarket... no change, tried a diff thermostat, i even pulled the engine to replace with an offroad cam, and fix an oil leak, i pulled the heads off and put new headgaskets in it at that time, i didnt like the way the factory shim gaskets fit.
its maybe 70-80 degrees outside, the engine was still very warm from the trip, i backed it out in the driveway, let it idle till it got just shy of 200 degrees, shut it off and i can move the fan pretty easily, it was pulling some air through pretty good when it was idling, bad fan??
Thanks!!
Matt
Old 06-08-2012, 04:04 AM
mine moves fairly easy also. maybe try a flex fan if you have one. Off the road cam may make it run a little hotter also. 4.10 gears? Any lead in your gas? Radiator flowing correctly?
Old 06-08-2012, 08:44 AM
91 octane, no lead. 3,73 gears. Radiator flows nice. I'm stumped!!
