Old 03-30-2012, 12:53 AM
dlv4540 dlv4540 is offline
Default 1966-69 Performance Heads, L89 CE Motor & 4 Speed
1966 3873858 heads rebuilt I-30-5 & J-4-5 $2500
1967 3904391 single head dated C-15-7 $1250
1967 3919840 heads dated E-18-7 & E-23-7 rebuilt $2500
1968 3919840 heads both dated L-12-7 $1250
1968 3919840 heads dated L-7-7 & L-11-7 ported $1000
1968 3919840 heads dated A-11-8 & A-12-8 $1250
1968 3919840 heads both dated F-18-8 $1250
1968 3919840 single head dated L-21-7 $500
1968 3919840 single head dated D-23-8 $500
1969 3919840 heads both dated A-22-9 $1250
1969 3919840 heads both dated B-20-9 rebuilt $1750
1969 Holley Carb #4346 dated 8B1 missing choke $600
1966 Spin on oil canister $25
964 4 bolt main caps and bolts two sets $150 per set
BBC Studs in GM box $50
BBC studs and guide plates $50
1969 396 CE counter exchange motor rebuilt casting number 3969854 dated F-11-9 with #077 aluminum heads, edelbrock intake, 3/8 dimple rods, dome pistons, solid camshaft never fired. The heads look just like the #842's and #074's and will look just like a real L89 engine. $7000 for the motor and can ship if you cannot pick up.
Richmond super T-10 transmission rebuilt with the 2.88 first gear and fine spline input shaft. Selling the tranny with the hurst shifter and linkage. Very durable transmission $2000.
Any questions or pictures needed I can be reached at 330-770-2517. Serious inquires only. All heads cleaned and magged and mostly all are stock sets.
Dennis Vugrinovich
