Old 02-27-2012, 02:39 PM
dlv4540 dlv4540 is offline
Default 1966 427-425HP Block, Internals & 3873858 Heads
1966 427 4 bolt standard bore block casting number 3869942 dated E-17-6 and front pad reads T05254D 6J276888. The block was cleaned and magged and might be able to stay standard bore. I also have the original pistons and rods for the block as well. $4000 for the set up and can be reached at 330-770-2517 for any questions or pictures needed. Can ship if you cannot pick up. Great block for a corvette, impala or biscayne. 1966 3873858 square port heads all rebuilt with a couple hundres miles on them dated I-30-5 and J-4-5. The heads are all stock and complete with H stamped rockers and poly locks. The heads have not been ported or milled and have the stock size valves built to stock specs $2750.
Dennis Vugrinovich
Old 03-11-2012, 12:36 AM
Default Re: 1966 427-425HP Block, Internals & 3873858 Heads
Updated
Dennis Vugrinovich
Old 03-15-2012, 12:38 AM
TAR6569 TAR6569 is offline
Wow. Cool block. Can you post a picture of the engine pad? Is the suffix actually ID not 4D?
Warren
381 and counting in the 67-69 Impala SS427 registry
Old 03-15-2012, 02:26 AM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: TAR6569</div><div class="ubbcode-body">Wow. Is the suffix actually ID not 4D?
Warren</div></div>
Wouldn't Corvette be IP?
Jake Dykstra
Dykstra Motorsports
Old 03-15-2012, 02:50 AM
&quot;6J276888&quot; would be from a 1966 full size Chevrolet built in the Janesville Wisconsin plant. A 1966 Corvette would be &quot;6S------ for the St. Louis Mo. plant. If you google 427/425 Chevrolet suffix: ID 1966 427 425 Chevrolet SHP
Bill
Old 03-15-2012, 04:29 AM
I believe it is a mistamp from the factory and should be ID but was stamped as 4D. I can send a picture to your email address if you provide it. I have a hard time posting pictures on this site. I figured if someone wants to use it for a corvette they can always deck the block and get rid of the stampings. It is a real 4 bolt block by the reliefs cut out of the top of the cylinders along with the larger holes down by the oil filter.
Dennis Vugrinovich
Old 03-19-2012, 01:02 AM
Thanks in advance for sending the picture. My email is [email protected]
Warren
Old 03-19-2012, 04:37 PM
I will send you a picture of the front pad stamping.
Dennis Vugrinovich
