Old 02-09-2012, 09:24 PM
Edgemontvillage's Avatar
Edgemontvillage Edgemontvillage is offline
Default 69 Z/28 Small Parts Needed - Updated 3/13
<span style="color: #3366FF"><span style="font-weight: bold">Located ALMOST everything on the list, still looking for a set of original control arm dust shields.</span></span>
The details make all the difference. I need a few small parts and fasteners to correct some deficiencies on my mostly original '69 Z and would appreciate any leads or help locating the following in good, used condition suitable for use on a survior car:
- <span style="text-decoration: line-through">Original cowl induction flap frame to hood bolts (6) </span> <span style="font-weight: bold">LOCATED</span>
- <span style="text-decoration: line-through">Original console gauge cover screws </span>(2)
- <span style="text-decoration: line-through">Cowl induction air cleaner top ring with original &quot;rear&quot; sticker </span><span style="font-weight: bold">LOCATED</span>
<span style="font-weight: bold">- Original (both) inner fender/upper control arm dust/splash shields (stapled)</span>
- <span style="text-decoration: line-through">Original heater hose fittings/nipples (2) (1 each for manifold and water pump)</span><span style="font-weight: bold">LOCATED</span>
- <span style="text-decoration: line-through">Original radiator to rad support screws &amp; captured (rubber) nut inserts (drivers side)</span> <span style="font-weight: bold">LOCATED</span>
- <span style="text-decoration: line-through">Original leaf spring U-bolt + stud nuts (nuts only) (8) in good condition </span><span style="font-weight: bold">LOCATED</span>
[- <span style="text-decoration: line-through">Original Muncie trans yoke (good condition w/o score marks)</span> <span style="font-weight: bold">LOCATED</span>
<span style="font-weight: bold">UPDATED 3/13/12</span>
Old 02-17-2012, 01:51 AM
bob f bob f is offline
Default Re: 69 Z/28 Small Parts Needed
If it can be of any help I have the original water pump and starter off my 70 yenko nova .
Old 02-18-2012, 07:09 PM
Thanks for the offer Bob, If you have the heater hose inlet nipples, 1 from the top of the water pump as shown and possibly the other from the intake manifold I could use both.
Old 02-18-2012, 10:03 PM
crash crash is offline
Do you still need a trans yoke??? Crash
[email protected]
Old 02-19-2012, 12:42 AM
Yes, still looking for a yoke, email sent.
Thanks.
Old 03-03-2012, 08:49 PM
Default Re: 69 Z/28 Small Parts Needed - Updated 2/18
Updated 3/3/12
Old 03-05-2012, 02:10 AM
Did you get the pictures of the trans yokes I E-mailed you ??? Crash
