Old 01-18-2012, 05:43 PM
TXSS TXSS is offline
Default WTB: Set of shifter levers for M-22
I'm looking for a factory set of shifter levers for a 69 Camaro with an M-22 and a factory Hurst shifter. I could use one of the factory correct sets Heartbeat or Rick's sells in the interim but they have been out of stock for months.
Thanks
Rick
Old 01-18-2012, 07:28 PM
Hemicolt Hemicolt is offline
Default Re: WTB: Set of shifter levers for M-22
I have a bunch of nos shift levers and rods from Hurst. Do you know the part numbers you are needing?
It's not the critic that counts, not the man who points out how the strong man stumbled or whether the doer of deeds could have done them better...
Old 01-19-2012, 06:28 PM
Tracy
Thanks for the reply.
I believe I need 2/ea 9798541 and 1ea 3955769
That's what the assembly manual shows for a 69 BB with M-22
Rick
Rick
Old 01-19-2012, 06:37 PM
You're welcome.
I'll check and see what I have. May take a couple of days as my parts collection is at another location.
Old 01-19-2012, 08:04 PM
How about a kit like this:
http://www.ebay.com/itm/Camaro-69-Hurst-Shifter-Linkage-Rods-Kit-Big-Block-1969-/370369402270?fits=Year:1969|Model:Camaro&hash= item563bbc959e&item=370369402270
Old 01-19-2012, 09:14 PM
Tracy, thanks that sounds good.
Jason, That's a good kit. I'v used then many times. In this case I've alredy got all the other original parts and just need the levers. I'd perfer originals. The levers that come with this kit work perfectly but they can't be purchsed seperatly and the assy line correct after market sets have been out of stock for 4 mounths. I got a set from Hurst that were represented as being the same as in the kit but they were to thich and once in reverse the shifter was locked in reverse.
Thanks
Rick
Old 01-24-2012, 03:40 AM
pm sent.
