Old 12-27-2011, 07:38 PM
Guest
Posts: n/a
Default Garage Clean Out!
<span style="text-decoration: underline"><span style="font-weight: bold">Garage Clean Out Sale</span></span>
Here’s a list of the parts for the sale. The first section includes parts that are new and in original packaging, unless noted. The second section includes parts from a very low mileage (9,317) 1969 Nova I have available.
The following parts are either new or mint. I have photos of many of them and can send photos if required. I’m open to reasonable offers on these pieces. No lowballs please (please!), as these parts are already priced attractively!
<span style="font-style: italic"><span style="font-weight: bold">New (and a few Used) Parts…</span></span>
*Crane Pro Series One-Piece Pushrods Big Block Chevy. Part # 13643-16 3/8-inch diameter, heat-treated. Measure 7.950-inches intake and 8.950-inches exhaust for Tall Deck (10.200-inch deck height) engine. New in the original Crane box. The regular price (at Summit Racing) is $179.99. My price reduced to $140.
*McLeod Mini Starter #810152. Chevrolet applications. Billet block mount, black powder coated motor. Double drilled for large or small diameter flywheel/flexplate. Summit’s Price is $259.95. My price is $225.00
*Moroso Four-Hole Carb Spacer. 4-Hole 4150 (standard) Holley pattern. ½-inch thick; 1.75-inch holes. Laminated hardwood design. New. Jeg’s price is $27.99. My price is $22.00
*Moroso Four-Hole Aluminum Carb Spacer. 4-Hole 4150 (standard) Holley pattern. ½-inch thick; 1.75-inch holes. Aluminum design. New. Jeg’s price is $55.99. My price is $45.00
*Moroso Aluminum Carb Wedge Plate. Tilts carb forward 5-degrees to level carburetor during acceleration. Open plenum design for Holley 4150 carburetor. Jeg’s price is $31.99. My price is $25.00
*HVH Super Sucker Carb Spacer. 4500-series Dominator 4-hole “composite” spacer. 1-inch thick; 2.0-inch holes. Super sucker carburetor spacers are the most effective carburetor spacers ever developed. Adds up to 47 HP naturally aspirated. Super Sucker carb spacer designed to properly distribute the air/fuel mixture to the manifold. HVH price is $88.00. My price is $75.00
*HVH Super Sucker Carb Spacer. 4150-series split “composite” spacer. 1-inch thick; split (long) holes for dual plane intake manifold. Super sucker carburetor spacers are the most effective carburetor spacers ever developed. Adds up to 47 HP naturally aspirated. Super Sucker carb spacer designed to properly distribute the air/fuel mixture to the manifold. HVH price is $88.00. My price is $75.00
*Autometer #3203 Chrome gauge mount cup (for 2-5/8-inch gauges), new in original package. Jeg’s price: $26.99. My price is reduced to $19
*Autometer #3231. 2-5/8-inch gauge panel, single, black. New, some shelf wear to finish. Jeg’s price: $14.99. My price is reduced to $9
*Moroso #97230 electric water pump drive replacement belt (21-inches in length), new in original package. Jeg’s price: 15.99. My price is $9
*Set of Four Pro Topline Small Block Chevy Pushrod Guideplates, fit a 7/16-inch rocker stud with a 5/16-inch pushrod. Straight configuration, new. The big mail order companies price these rocker studs at $8.99 for a set of four. My price for a set of four is $7.
*Set of Eight Pro Topline Rocker Studs, Small Block Chevy 7/16-inch cylinder head, 3/8-inch fine thread @ rocker (thread is 0.950-inch long), new. The big mail order companies price these rocker studs at $17.99 for a set of eight. My price for a set of eight is $15
*Set of Four Pro Topline Small Block Chevy 2.02X5” stainless steel valves, 11/32-inch stem, undercut to 0.295-inch under head. New. The big mail order companies price these valves at $81.99. My price is $59
*Set of Four Pro Topline Small Block Chevy 1.60X5” stainless steel valves, 11/32-inch stem, undercut to 0.295-inch under head. New. The big mail order companies price these valves at $72.49. My price is $49.
*Set of Four Pro Topline Small Block Chevy 2.15X5.625” stainless steel valves (0.700-inch longer than stock), 11/32-inch stem, 0.295-inch under head. New. The big mail order companies price these valves at $81.99. My price is $59
*Flaming River FR1750PL steering universal joint, billet smooth bore 0.750-inch DD X 0.750-inch tube, plated, new. This U-joint is CNC machined from aircraft steel to precision tolerances. Sealed needle-bearing design. The big mail order companies price this universal joint at $94.90. My price: $69
*Flaming River FR1707DDPL Steering Universal Joint - billet smooth bore 1.00 DD X 0.750-inch tube, plated, new. This U-joint is CNC machined from aircraft steel to precision tolerances. Sealed needle-bearing design. My Price: $69
*Moroso 3/4X3/4 Rod End. Economy style. One only. $9
*Moroso 64000 17-inch stainless steel flex fan. New. Not in original package. Jeg’s price: $46.99. My price: $39
*Comp Cams #1021-1 Roller Rocker (aluminum) for Big Block Chevy. 1.7:1 ratio. One only. In original package. Jeg’s price: $19.99. My price: $14
*Borgeson Pitman Arm, GM manual steering. Flat configuration. Jegs price: $74.99. My price: $49
*Borgeson #990012 ¾-30 half rag joint. New in original package. Jegs price: $74.99. My price: $49
*MSD 8222 Blaster Coil. New in original package. Jeg’s price: $47.99. My price: $40
*MSD Cap Adapter. New. No box. Fits Delco point style &amp; MSD distributors. Has been sitting for years. $35
*Strange Engineering Dana 60 Cover. New. Cast Aluminum with bolts. $65
*Competition Engineering Roll Bar Main Hoop Only. New. Nova/Camaro. $45
*ACCEL Chrome Coil. Vintage job from the late Sixties. Clean. Worked when I removed it from the car decades ago. $25
*Buick Regal (1981-87) Dash Insert (gauge panel). 3-3/8-inch Speedo &amp; Tach &amp; Four 2.00-inch gauges. $30
*Buick Regal (1981-87) Dash Insert (gauge panel). 3-3/8-inch Speedo &amp; Eight 2.00-inch gauges. $30
*Buick Turbo V6 Starter, used $45
*Aurora Bearing Rod Ends
QTY P/N Description
__________________________________________________ ______________
4 RXAB-10T Extra HD 5/8X3/4-16 LH; Teflon $55 each
5 RXAM-10T Extra HD 5/8X3/4-16 RH; Teflon $55 each
2 VCM-6 3/8X3/8-24 RH; Teflon $11 each
2 VCB-6 3/8X3/8-24 LH; Teflon $11 each
2 AIB-12 HD 3/4 Spherical Bearing $15 each
4 AM-12T 3/4X3/4-16 RH; Teflon $40 each
2 AB-12T 3/4X3/4-16 LH; Teflon $40 each
4 RXAB-8T-3 Extra HD 1/2X5/8-18 LH; Teflon $45 each
4 RAXM-8T-3 Extra HD 1/2X5/8-18 RH; Teflon $45 each
2 XAB-8 HD 1/2X5/8-18 LH $27 each
3 HXAB-8T HD Hi-Misalignment 1/2X5/8-18 LH; Teflon $29 each
3 HXAM-8T HD Hi-Misalignment 1/2X5/8-18 RH; Teflon $29 each
4 PRM-10T 5/8X5/8-18 RH; Teflon $30 each
1 PRM-8T 1/2X1/2-20 RH; Teflon $27 each
2 PNB-1OT 5/8 Spherical Bearing; Teflon $30 each
1 PWB-12T ¾ Spherical Bearing; Teflon $31
*QA1 Rod Ends
4 XMR12 3/4X3/4-16 RH $20 each
4 XMR8 1/2X1/2-20 RH $15 each
*1975-77 Chev/GMC Dash Bezel (black). New. $119
<span style="font-style: italic"><span style="font-weight: bold">New &amp; Used 1969 Nova Parts…</span></span>
*New Old Stock GM Rag Joint. Part Number 780639. $125.00
*New Old Stock GM Headlamp Bezel. Part Number 03949790. $169.00
*Delphi Manual Steering Box (525 box, standard ratio), new in original box. $333
*L88 LS6 L71 L72 ZL1 Chevrolet Corvette, Camaro, Chevelle Big Block Rocker Arm studs, 7/16. New Old Stock OEM Chevrolet. $40.00
Note: Most of the following used were removed from my 1969 Nova two door sedan with 9,317 original miles (no misprint). Parts are obviously very nice, and sorry the Nova isn’t for sale (yet)!
*Small Block Crankshaft Pulley. Car had power steering. Pulley is in very nice overall condition. $29
*Small Block Water Pump Pulley. Very nice overall condition. $29
*Alternator Pulley. Standard groove configuration. Very nice overall condition. $10
*Small Block Heater Core. Perfect shape. Includes seal. $39
*Small Block Heater Core Cover. This is the heater shroud in the engine compartment. Very nice overall condition. $29
*Windshield Washer Jar. Has some yellowing, but otherwise perfect. $9
*Original Gas Tank. **Tank is Damaged**. Has a dent on one side. Includes a mint sending unit. No cap. $69
*LH Nova Tail Lamp Housing. **Housing is Damaged**. $5
*Small block valve cover to air cleaner hose, pipe, grommet &amp; clamps. Mint. $5
*Side marker lens assemblies, new. Complete set of 4. No chrome trim. $25
*Twist in oil filler cap. Very nice painted original. $7
*Mirror base gasket (driver side) $1
*Wire gutter (at firewall cowl); one hole has a tear in it. $1
*Automatic transmission reverse interlock. $20
*Steering rag joint. Very nice condition. $25
*Nova script front fender emblems. Nice shape. $20 each
*Fan clutch (1968 Nova &amp; 396 Camaro). New. $150
*Stick shift pedals (pedals only; no clips or bushings). New. Reproduction. $75
*Aero wiper blades. New. Reproduction. $50
*Column shift steering column, partial. Includes lower + Upper key/turn signal housing &amp; shifter housing. Very nice condition. Upper key/turn signal housing has small flat dent. $40
*Shoulder harness strap. Pale green in color. $2
*Park lens gaskets. Nice shape. $2
*Hood to cowl ledge weatherstrip. Nice shape. $5
*Front bumper bracket, passenger side inner. Fresh powder coat. Mint. $15
*Front bumper bracket, passenger side outer. Dented. Can be repaired. $5
*Powerglide Transmission kickdown rod. Good shape. $5
*Carburetor air cleaner wing nut. Correct original. $5
*Rubber hood bumper set. Used. Decent shape. $2
*Windshield wiper motor mount bushings. Good condition. $2
*Front brake hoses (drum brake). Good condition. $10/pair
*Correct distributor clamp with correct hold down bolt. Nice shape. $49
*Internal horn switches (inside steering wheel). Mint. $5
*Hood lip molding (chrome trim for nose). Reproduction. Minor dents (can be repaired). $30
*Hood emblem. Reproduction. Not perfect; has minor ripples in it (driver quality). $20
For more Info, contact me:
Wayne Scraba
Qualicum Beach, BC, Canada
PH: 250-738-0530
E-Mail: [email protected]
