Old 12-07-2011, 08:14 PM
Default Original 454 LS6 Engine Complete Intake to Pan
This is a complete LS6 454/450 engine from carb to pan minus the cam and lifters. It was removed from a 1971 jet boat so the date codes are all late 70-early 71. This would make a great replacement engine for an LS6 Chevelle or other hi perf warranty engine.
The numbers on the engine are as follows:
Block casting number: 3963512 Factory 4 Bolt Main
Head Casting: 3964291 Factory Rectangular Port Hi Performance
Crank Forging Number: 7416 Factory Steel Crank, Nitrited and Cross Drilled
Piston: L2349 .030, TRW Forged Piston, 1970 LS6 Replacement
Rods: Hi Performance Chevrolet "Dimple" rods with factory 7/16" rod bolts
Intake: 3963569, Factory High Performance Aluminum Intake
This is an original LS6, not a cobbled together bunch of parts. The engine is complete from intake to pan minus the cam and lifters.
The block has been bored .030 over and has almost no use since then. The tops of the cylinders have ZERO ridge. There are no breaks, sleeves, or other repairs/damage.
The heads look great with no porting or modifications. The valves sit very high in all the seats. Even the original high lift "L" rockers are still intact.
$2750
Old 12-07-2011, 08:27 PM
Default Re: Original 454 LS6 Engine Complete Intake to Pan
Old 12-07-2011, 08:28 PM
Old 12-07-2011, 08:52 PM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
I have NOS cam, lifters, and valve springs if you are interested.
Old 12-07-2011, 09:11 PM
Damn fair price! Wish I had the extra cash and it was burning a hole in my pocket!
Old 12-07-2011, 09:15 PM
Ngtflyr Ngtflyr is offline
Sent you a PM
Dave
Old 12-07-2011, 09:58 PM
Sold pending payment.
Old 12-07-2011, 10:47 PM
XXXGoldL34M20's Avatar
That is a smoking good deal !!
I sold an LS5 from Carb to pan for $4000 a few weeks ago and this motor is a much better LS6.
Old 12-07-2011, 11:11 PM
Ooops, I guess this one sold too cheap. At least it is going to a member.
Old 12-20-2011, 11:14 PM
I bought this motor from Jason, the motor was used in a marine application. Got it home yesterday and it was as advertised. The plugs in the heads on the front end of the engine, are different than stock.
You can just make them out in the pic of the eng on the engine stand. I believe they are called "cold plugs" and I need to replace them with stock plugs. Can anyone point me to someplace where I can get replacement correct plugs. Every search I do refers to spark plugs.
Dave
