Old 11-20-2011, 03:23 PM
69L78's Avatar
69L78 69L78 is offline
Default Original GM X-Ram Setup Last offer here at $12,500
This is a complete X-Ram setup that is currently on my Z. Everything that you need to put on your car will be included. The intake and carbs are original GM, but I think the wide base air cleaner is a reproduction. Also included will be the NOS valve covers that I had machined so you can take them off to adjust the valves without having to remove the intake, I also had the finish on the valve covers dulled to look like originals, I did not want to machine my set of org non-dripper valve covers. I also have 2 foam seals for the air cleaner to hood seal.
X-Ram Top 3941130 dated 8/18/69
X-Ram Bottom 3941126 dated 10/1/69
Holley Carb's 3957859 List 4295 dated 914 & 962
Phone 717-737-5352
Asking $12,500.
