Old 10-29-2011, 05:52 PM
Fantomas Fantomas is offline
Default Phase III Super/Spark CD system instructions
Looking for the instructions to the Phase III ignition box, thanks.
Old 10-30-2011, 02:45 PM
JoeC JoeC is offline
Default Re: Phase III Super/Spark CD system instructions
are you just looking for the wire diagram to install it or whole book?
Old 10-30-2011, 06:08 PM
Wire diagram for installing it but either will be fine.
Old 10-30-2011, 09:45 PM
PxTx's Avatar
PxTx PxTx is offline
Okay, I'll share some pics, but don't ask me how I took this picture. Welcome to the site. Please post more about your project. The more pics the better.
Paul III
Paul III
Old 10-31-2011, 03:43 AM
Thanks Paul.
About my project, I am working on a 70' Camaro B/M clone that I have owned since 2008. Original 307 car, when purchased was a Z clone. Currently the car has a stock 454 mill, stock pistons, crank, mild cam with a 350 Turbo tranny and 3:42 rear gears.
I've just pretty much finished my 1969 Chevelle and now getting started on the Camaro for the winter. I'm replacing the stock 454 with a 505 BBC, which has Mahle pistons 11:1 compression, a 4.25 forged Scat crank, Crane Cams mech. flat tappet .580/.600 lift, Edelbrock TR2X tunnel ram topped with dual 600 Holleys, 8 qt. lubrication system. All of that will be backed up by a 400 Turbo trans, shift kit and a 5000 stall convertor. I'm thinking somewhere along the lines of 700 hp
I have the powerplant nearly completed and ready to go into the car. After that there will be some dressing up to do, which really isn't much. New paint, wheels and tires, etc. I'll try and have pictures up soon.
Old 11-19-2011, 03:42 AM
Still looking.
Or better yet where does the blue wire attached to the toggle switch connect to?
Old 11-19-2011, 05:38 AM
PxTx's Avatar
Blue wire to engine ground, such as a carburetor bolt they recommend.
It actually isn't a ground wire, it senses the voltage kick when spark jumps from the center electrode to the side electrode. If the blue wire is not properly connected, you loose 70% of the systems ability to sense engine needs.
Paul III
Old 11-19-2011, 02:42 PM
scott s scott s is offline
Paul helped me on the hookup of my box also thanks. i believe the blue wire gets grounded thou.
Old 11-21-2011, 06:18 PM
PxTx's Avatar
Adam Tuckman just sent me a file with these in it and I'm posting with his approval. Pretty cool to see some original literature on hooking up one of these boxes from Motion. Don't think this actually addresses the blue wire issue, but we sorted that out above.
Paul III
Old 04-07-2012, 05:03 AM
