Old 10-17-2011, 12:39 AM
Al70 Al70 is offline
Default Fan Belt for 1970 Nova Deuce
I am trying to find out the correct fan belt for my 70 Deuce. The only thing it runs is the alternator, water pump and smog pump. Can someone tell me the correct length and possibly the correct GM code for this belt. Many thanks
Old 10-17-2011, 02:44 AM
wheelhop wheelhop is offline
Default Re: Fan Belt for 1970 Nova Deuce
Try Quanta Products LLC. , they are a lisenced gm supplier of fan belts.
GASTANKS.com
Old 10-17-2011, 02:52 AM
Thanks, I will check that out.
Old 10-17-2011, 03:11 AM
mockingbird812's Avatar
Alan - that is where I bought both of my fan belts; one for the stock set with smog pump & the one for the day-two with no stinkin smog pump:
Sam...
Old 10-17-2011, 03:41 AM
Sam
Many thanks for the picture. It looks like your tension bolt is right in the perfect place. Can you tell me the length and GM part number of the belt that you use with the smog pump?
Too bad that Yenko had to put those wheezers on the cars so they could sell them in California. All they do is hog horsepower and help to burn valves. But I guess it was what they thought would keep the smoggies in CA happy.
Alan
Old 10-17-2011, 03:46 AM
Alan - am away from home till Thanksgiving and do not have access to that info. I will gladly get it for you then. Schonye or Marlin may be able to help you.
Sam...
Old 10-17-2011, 03:53 AM
Thanks Sam.
Old 10-17-2011, 09:43 PM
All 1970 Nova LT-1 or Camaro Z/28 Fan/Alt.belt w/A.I.R #3883248.Measures out @ 3/8 X 47".Later on superseded by belt #9433746 during sometime after 1973.
I think you want 29-B-725 here.. http://www.gastanks.com/1970/products/531/
Old 10-18-2011, 04:22 AM
Thanks very much for the information. I will contact them for the belt.
Old 10-18-2011, 09:29 PM
Ask them to please measure the belt before they ship it to you,to be sure you're getting the right one.
The more common V8 smallblocks WITHOUT A.I.R.,used belt #3953786 that was 3/8 X 44" long.
