Old 10-13-2011, 02:07 PM
Atuckman Atuckman is offline
Default Day2 Shocks
Looking for rear pair or a full set of period correct drag shocks for a 70 chevelle ahead of the MCACN. the cure-rdes i have arent going to work unfortunately. any other suggestions? leads?
thanks adam
Old 10-13-2011, 09:36 PM
whitetop whitetop is offline
Default Re: Day2 Shocks
If you are really in a pinch buy a set of heavy duty truck shocks with the same ends and length, paint them correct colors and have a vinyl graphics/decal shop make you up some decals. The books at Napa have all the specs/sizes in back of the catalog or go online.
Most people out there would not know the difference and they are difficult to see anyway.Roll em around on the garage floor for some period scrapes(patina) and maybe some weathering with a chemical mix and you will be all set.
Old 10-13-2011, 09:49 PM
You are the MAN Dave!
Old 10-13-2011, 10:51 PM
Jeff Murphy Jeff Murphy is offline
The other thing you can do is buy these: KONI Classic Shocks at Summit and carefully cut the "Classic" part of the decal off. They will look period correct.
Jeff M.
ZL1 #49 (Dale, Waukesha WI) Super Stock restoration by SCW; 9561AA (Walters, Hebron OH) Super Stock motor by the Grump
Old 10-14-2011, 01:53 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: [email protected]</div><div class="ubbcode-body">You are the MAN Dave! </div></div>
After going back and reading my response it appears I was winging it. There was an old article in a late 70's PHR mag from a shock tech article stated a Gabriel or Monroe shock spokesperson said they used truck shocks for their drag shocks due to the beefier housing and thicker shaft but incorporated proprietary valving (which you don't see of course) to make it a &quot;drag shock&quot;
The valving(90/10/70/30 etc) was in affect the only special &quot;drag&quot; portion of the shock..the rest was just an oem shock.
I believe Gabriel made all the shocks for Hurst.
Old 10-14-2011, 04:04 AM
PxTx's Avatar
PxTx PxTx is offline
Reproduction decals are available from CJ Pony Parts.
Somehow I don't think reproduction is gonna be acceptable from comments Adam when he was shared pics of his vintage decals.
Paul III
Old 10-14-2011, 05:34 AM
MosportGreen66's Avatar
Adam has stacks of those decals in his living room... he's asking about the physical shock.
Old 10-14-2011, 04:32 PM
thank you for the suggestions. i bought two of the koni classics for the rear until i find an old set of cure-rides
appreciate the help
adam
Old 10-14-2011, 09:47 PM
Nobody will ever know whats on your car Adam. Can hardly see them. A good decision on your part.
