Old 10-03-2011, 09:02 AM
hvychev hvychev is offline
Default Acid rain spots on windshield
Hey guys, just need a little help. I have a 2003 Crown Vic as my daily driver and I have a ton of what I believe are acid rain spots on the windshield, which have been there for a few years now. They are starting to drive me nuts. I have tried to hit them at "point blank" range with a power washer and they still won't come out. Any suggestions on how to get rid of them?
Frank Magallon
Old 10-03-2011, 03:05 PM
Default Re: Acid rain spots on windshield
Frank,
Try Mr. Clean Magic Eraser.....if it worked great at my vinyl top...I would think it would help your situation.
Post back on your results.
http://www.mrclean.com/en_US/magic-eraser.do
Old 10-03-2011, 03:13 PM
m22mike's Avatar
m22mike m22mike is offline
When my wind screens get allot of road film I have used Bon Ami and water to scrub the glass with, usually at car wash time. Just enough abrasive to polish the crud off the glass. Might work on the spots too ? Bar Keepers friend should work too.
Mike
Old 10-03-2011, 04:26 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Simple and cheap boater's cleaning idea.
Try a 50/50 mix of water and vinegar. Put in spray bottle and spray on.
Works great for water spots on boats baked on by the sun - can use on painted surfaces too.
Jake
Jake Dykstra
Dykstra Motorsports
Old 10-03-2011, 04:57 PM
ORIGLS6 ORIGLS6 is offline
Polishing compound on a low-speed buffing pad will work too. Just be sure to keep it cool.
How about the new headlight restore kits???? [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Old 10-03-2011, 08:20 PM
juliosz's Avatar
juliosz juliosz is offline
Use 00 steel wool and glass cleaner...works beautiful....saturate the glass with glass cleaner and work the surface with the steel wool...it comes out beautiful, gets all of the contaminates off.
Paul
Old 10-03-2011, 10:27 PM
Water spots can be quite tough. They are very common in Hawaii due to the sulfur and other junk in the air from the volcano. I worked at NAPA on the big island and we sold a solution specifically for these water spots. Maybe do an online search for water spot removal solution? The other ideas are good but if these are the same type of spots we would get on the islands you will need more that steel wool and windex. The solution we sold was in a white bottle with green lettering IIRC.
Old 10-04-2011, 12:17 AM
Jason,
Was it Ducky?
Old 10-04-2011, 12:41 AM
I don't remember. I do remember it came with a white brillo pad and was most likely a mild acid.
Old 10-04-2011, 12:44 AM
It may have been this stuff:
http://colker.jracenstein.com/store/...85-510&amp;Tp=
It looks like there are many similar products on the market that will probably give the same results.
