Old 09-28-2011, 05:07 AM
XXXGoldL34M20's Avatar
XXXGoldL34M20 XXXGoldL34M20 is online now
Default Amp gauge needle now facing upside down on my SS
My Horns did not work earlier this week on my 70 Chevelle SS so i took the original 890 horn relay off for a good clean up inside.
The relay just needed a good clean up and some gentle sand paper scuffed along the 2 contacts under the cover.
The Buzzer now screams and the horns work like they should.
The next problem though was when i looked at the Amp Needle on the SS gauges it was pointing to the 6 o'clock position instead of the 12 o'clock position [img]<<GRAEMLIN_URL>>/frown.gif[/img] .
When i turn the car on the gauge still works but it moves in the upside down position.
A friend of mine told me if i grab a 1.5 volt AA battery and touch the contacts of the back of the gauge that it may bring the needle back to its proper position?
I even herd that it may go back eventually on it's own.
Any opinions on what to do before i start taking the dash apart?
Old 09-28-2011, 05:07 PM
Default Re: Amp gauge needle now facing upside down on my SS
Problem fixed,
I got a new AA battery and added wires tape and held in place with electrical tape, then i hooked them up to the rear terminals on the back of the Amp gauge after removing the top of the dash and stereo speaker and i unhooked the car battery before doing anything.
The needle jumped right back to it's original 12 o'clock spot [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Here is a photo of the little tool that solved the problem.
Old 09-28-2011, 06:02 PM
Leaned something new Danny. Thanks for sharing!
