Old 09-26-2011, 08:09 PM
Fast67VelleN2O's Avatar
Default Parts headed to Carlisle. Lots of good stuff.
1968-1972 Chevelle 4.10 12 bolt posi Rear. Nothing special code. $950.
1968-1972 Chevelle 3.31 12 Bolt Posi Rear. Has ring gear spacer. Nothing special code. $825.
1968-1972 Chevelle Moser 9" Rear End. Aftermarket housing, 3.90 gears, 31 spline axles, traction Lock posi unit. $1300.
1970 Camaro 12 Bolt 3.73 Posi. Coded COZ out of Z28. Richmond gears, posi unit has some marks, nothing major $900.
1969 427 block. 512 casting .030" Dated May of 1969. was decked, no codes or vin. $1800.
1968 427 Block. 321 casting. Out of Corvette L89, Fresh .060", was discussed here on SYC. Car is known. $2200.
1967 327 shortblock. 657 casting, no codes or vin, .030", 11:1 L79 pistons, steel crank. Needs freshening. $600.
Service dated 291 square ports. Have been ported but nothing major. Valves are present but no other hardware. $600.
1970 Chevrolet 454 291 square port heads. No porting. Dated K-28-9 and L-8-9. Nice used heads. No guide plates. $900.
1969 Chevrolet 396 or 427 square port heads. No porting. 3919840 dated C-35-9 and C-27-9. Complete. Good cores. $900.
1971 Camaro Z28 350 block. 3970010 dated C-24-1. Stamped V0326CGP. Vin 11N563805. Standard bore 4 bolt. $675.
Lots more but this is stuff off the top of my head. Spaces G41 and G42.
-Matt
Day 2 is Life.
