Old 08-28-2011, 05:26 AM
Default slow heating
OK, Maybe someone has an idea,
Im pretty sure this is the factory set up. radiator recored, water pump ok, thermostat replaced, stock timing setting, clean coolant.
Problem: Sitting at idle the car will slowly heat, and continue to heat up very slowly, if I drive it will cool back down,
The assembly manual shows the setup as you see, assuming it is stock, any ideas?? It is now running a 180 standard themostat, oem appears to be 195. Assuming factory stock the system even though build without a shroud should run at the thermostate temp?? shouldn't it
Carl
