Old 08-04-2011, 04:08 PM
Default 68 Camaro parts needed
Need for 68 Camaro 396;
Shifter rods and fingers
3930063-1st and 2nd rod
3930065-3rd and 4th rod
3930067-reverse rod
I also need the stabilizer rod from the shifter 3913710. Also, where the shifter mount mounts to the crossmember, there are two threaded plated that the attaching bolts thread into. One has two holes while the other has only one. I need both of these. Might also need the square headed shifter to mount bolt.
Need 68 AM radio fender antenna. NOS or MINT used.
Need 396/375 fan and clutch for same.
Rick
