Old 07-12-2011, 06:52 AM
Default HARRISON Radiator I.D. HElp Needed
Hello, I have a HARRISON radiator I'd like to ID the application
It is similar to a 70+ Camaro/Firebird radiator in that it appears to sit in those rubber pcs that fit into core support base area. It would then have a metal top hold down plate with the same rubbers holding inner edges
of tanks (R & L)
This radiator measures approx 28 3/4" from center/center where it would sit in those rubber pcs
28 3/4" C/C are those inner tank edges (??)
Right side tank is embossed A on one rib and J on next lower, with L and 1 (below the L) between the A & J.
Right tank also embossed with Harrison
I cant see any embossing on left tank.
Do you recognize this as being from a Chevelle or ???
__________________________________________________ ____________-
I also am looking for mfg that still offers OEM style 2 Row Core for 70 Z-28. These 70+ F-Body radiators
have a hat shaped metal piece that runs along top and bottom of core connecting tanks together.
Will need quality shop to install new two row core in my 70 Z-28 tanks
Thanks for your help.
Chuck Sharin
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
