Old 07-08-2011, 02:28 PM
sah62's Avatar
sah62 sah62 is offline
Default Brake Valve Identification and Advice Needed
I recently removed a pressure differential valve/distribution block from the left front frame rail of a 1970 Chevrolet Impala. I'd like to understand if the same (or similar) valve was used on any other Chevy or GM vehicles. The InlineTube web site (Product Info) lists several applications (including 1970 Impala), but the valve body in their picture looks a little different than the one I removed. Here's what I removed and how it can be disassembled:
http://www.musclecarresearch.com/197...-valve-autopsy
I'm asking because my company (see my sig) is in the business of producing rebuild kits for a small number of brake valves and I'm looking to expand into other applications. I <span style="font-style: italic">can</span> provide the parts to rebuild valves like this one, but I need to confirm two things first:
<ul style="list-style-type: disc">[*]Original applications, and[*]Interest - are people looking to rebuild these valves?[/list]Are the applications listed on the InlineTube page correct? Would you be interested in a rebuild kit if it cost approximately $20 - $25 or less? Do you know of other brake valves that might be worth rebuilding if a kit were available?
Scott Hollenbeck
Administrator, Mustang 428 Cobra Jet Registry
Owner, Muscle Car Research LLC
1970 Ford Mustang Mach 1
1995 Chevrolet Impala SS
2019 Lincoln MKZ 3.0T AWD
