Old 07-03-2011, 04:18 AM
travlnz28 travlnz28 is offline
Default Need Recomendations for ZL1 Block Repair
I have a Feb. 69 dated block and have decided it's time to get it fixed. It needs some welding and new sleeves installed. Does anybody know of a reputable builder in Southern California that has experience in aluminum and can handle it?
Old 07-03-2011, 04:43 PM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
Default Re: Need Recomendations for ZL1 Block Repair
I have a couple leads for you Gregg:
Total Performance in Santee619)562-9894 did the machine work on my ZL-1 block and can probably do the work or will know someone that can.
Auto Power in Oceanside: (760)722-1556 welded up and re-machined a valve seat on one of my 074 heads.
Old 07-03-2011, 09:02 PM
William William is offline
Be sure to have the sleeves notched if you plan on 7/16" rod bolts.
Any numbers on the block? The OE engine from our ZL-1 resto years back went to CA.
Old 07-04-2011, 06:19 PM
Greg,
Thanks for the tips. I'll check them out.
William,
The block was decked at some point. I bought it from a guy in Salem, Oregon. It has the name Alvey stamped on the deck now.
67 Camaro RS/SS 396 Original Drivetrain
70 Chevelle SS 396 Convertible Original Drivetrain
70 Chevelle SS 454 LS5 Survivor Original Drivetrain
70 El Camino SS 396 Original Drivetrain
65 Impala 396/425
65 Triumph TR4 Original Family Owned
Old 07-04-2011, 06:53 PM
Thanks.
Our ZL-1 engine went into a '71 Camaro PRO car and was raced in NED for two seasons. They built a Vega for '73 and sold the Camaro intact to someone in CA.
