Old 06-19-2011, 05:34 PM
enio45 enio45 is offline
Default 69 Z28 Rear Axle
Im working on a friends 69Z and noticed that the rear axle on one side has a casting or part number on the exposed end of the axle. The other axle has no casting numbers on it. The number is 9349 LS
My question is, do the 69 axles have casting numbers and if not, would one of the axles be a replacement?
Appreciate any advise on what is correct etc -
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 06-20-2011, 03:25 AM
wundercluck wundercluck is offline
Default Re: 69 Z28 Rear Axle
My JL8 car has 7206 (if memory serves), which were the last four digits of a JL8 axle part number, cast in the area you are referring to. I thought it was on both axles but haven't looked in a while.
Old 06-20-2011, 03:52 PM
"My question is, do the 69 axles have casting numbers and if not, would one of the axles be a replacement?"
Yes, Ed they have a casted part # on the ends of the axle.
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
69 RS/Z28 Maroon JL8
66 Corvette Ermine White L75
Old 06-20-2011, 05:26 PM
OK, from what i have been able to check out so far - the part number for the axle is 3969349 - so the axle would have a cast number of 9349 like the one im looking at. The other side does not have any casting info - so i am assuming its been replaced with a generic brand.
Any idea what the casting letters LS mean?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 06-21-2011, 01:54 AM
travlnz28 travlnz28 is offline
Ed,
Both of my JL8 axles have 7206 on the end (part # 3947206). I have a few other GM axles laying around and they all have numbers on the end. My guess is the one without numbers would be a replacement.
67 Camaro RS/SS 396 Original Drivetrain
70 Chevelle SS 396 Convertible Original Drivetrain
70 Chevelle SS 454 LS5 Survivor Original Drivetrain
70 El Camino SS 396 Original Drivetrain
65 Impala 396/425
65 Triumph TR4 Original Family Owned
Old 06-21-2011, 03:15 AM
doesn't matter, can't see them anyways. slide em back in Ed and go do a burnout. YEAAA!
Old 06-21-2011, 09:16 PM
You got the right idea Sammmmmmmmmyyyyyyyyyyyyyyyy!!
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 06-23-2011, 03:53 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: enio45</div><div class="ubbcode-body">OK, from what i have been able to check out so far - the part number for the axle is 3969349 - so the axle would have a cast number of 9349 like the one im looking at. The other side does not have any casting info - so i am assuming its been replaced with a generic brand.
Any idea what the casting letters LS mean? </div></div>
The LS means &quot;left Side&quot; and should only be used on the left side unless you live below the Equator. In that case you will need to move it to the right side or your gas mileage will severely drop. It's just like the direction water swirls in a toilet. It changes depending weather you are above or below the Equator because of the magnetic pull of the North and south poles. If you have the axle on the wrong side it will be just like trying to swim against the swirl in that toilet. Go with the flow. Ta Daaaa..
Old 06-23-2011, 04:28 PM
Leave it to Chaz to come up with the answer we all have been looking for!!!!
1969 Hurst/Olds
13.26 @ 103.12 Pure Stock
Rusty Small
Old 06-23-2011, 04:47 PM
What happens if you have one wheel north of the equator and the other south of the equator.....that would be a CF!
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
