Old 06-05-2011, 11:04 PM
ALLZS ALLZS is offline
Default REARENDS 12 & 10 BOLTS CAMARO / NOVA
WELL I AM CLEANING OUT MY GARAGE !! I AM GOING TO SELL ALL MY CHEVY REARENDS ALL HAVE BEEN DISASAMBLED HOT TANKED CLEAN AND HOUSINGS PAINTED THE CORRECT SHADE OF BLACK THE POSI UNITS WHERE ALSO WERE DISASAMBLED CLEANED CHECKED & REBUILT CLUTCH PACKS NEW BEARINGS & SEALS SOME ARE COMPLETE DRUM TO DRUM WITH ALL NEW BRAKE HARDWARE & ORIGINAL STYLE BRAKE DRUMS AND SOME ARE BACKING PLATE TO BACKING PLATE NO BRAKE HARDWARE. ALL THE HOUSINGS ARE IN VERY NICE SHAPE SOME HAVE VERY VERY LIGHT PITTING BUT NOT BAD AT ALL MOST OF THERE REAREND HAVE BEEN INSIDE FOR THE LAST 25 YEARS PRICES VARY ON DATE & CODES HERES A LIST OF SOME OF THE REARENDS . 12 BOLTS - BU-1227G1 -L-15-8 &BU-0531G2 - E-14-9 & BU0424G2 - D-14-9 ALL THE BU REAREND ARE 373 RATIO - BL0212G2 B-2-8 411 RATIO IN IT NOW & COV0624G1 E-19-70 HAS 331 RATIO IN IT NOW ALSO HAVE SOME 8.2 10 BOLT POSI & SOME 8.5 POSI THE 12 BOLTS & SOME OF THE 10 BOLTS WILL ALSO FIT NOVA . THESE ARE THE ONE I CAN GET TO RIGHT NOW I ALSO HAVE SOME BT & BV CODED 12 BOLTS NEED TO PULL THEM OUT & CHECK BUILD & CASTING CODES SEND ME A EMAIL OR YOU CAN REACH ME @ 314-504-8331 rearend range from $ 800.00 to $2000.00 plus any shiping thanks
