Old 04-25-2011, 01:38 PM
Thomas Thomas is offline
Default Engine Mount and Frame Mount Bolts
Do any of the restortion parts suppliers sell the correct engine mount bolts for a '69 BB Camaro?
I have looked through the online catalogs, but im not sure how correct they are.
The assembly manual shows only a bolt for this, not a separate Bolt and Lock washer.
The Parts Manual, dated 1970, shows the bolts to be 3/8-16 x7/8.
I believe this bolt has a "tall" hex head with a recess and a built in lock washer.
For the frame mounts, the assembly manual shows only a bolt and a nut.
The restoration parts suppliers show a bolt with a built in lock washer, a flat washer and locking nut.
The parts manual describes the bolt as a 1/8-16x1 1/8.
It makes no mention of the nut and does not show a washer.
There were a set of small block frame mounts, with a couple of bolts which looked original, at a flea market this weekend.
The bolt looked similar to the engine mount one described above and the nut appeared to be a flanged nut.
What is correct?
Thanks in advance.
Thomas Schilf
'69 Camaro SS, L78, M22, 4.10 Posi
'69 Camaro E/SA
'00 Camaro SS Convertible
'04 Harley FXST
'80 Chevy Blazer (My first new vehicle)
