Old 04-16-2011, 12:38 PM
iluv69s iluv69s is offline
Default 512 small block??
I picked up a small block chvy motor in a package deal..it is a CE stamped block...
It is cast number 512 I believe...seems like a 1960 or 61 cast date ? I believe L-8-0...or could it be 0-8-7 ?? has to be a 61 block, correct?
With a 4" bore?? would that be a 283 ? The motor is not here in my gar yet, so I am going by memory...
did they even have CE blocks in 1960
Old 04-16-2011, 06:03 PM
al8apex al8apex is offline
Default Re: 512 small block??
the 1st 4" bore Chevy small block was the 62 327 ...
283's had a 3.875 bore ...
what is the size of the front pad?
Jim R
Scottsdale, AZ
Old 04-20-2011, 12:38 AM
bcmiller bcmiller is offline
Must be a 70 block. They were not stamping engines as CE prior to 1968. Is it a large journal block or small journal?
Old 04-21-2011, 02:35 AM
From CRG
The 3959512 casting was mainly used for warranty / service blocks. It is a 4" bore block, thus could have 302, 327, or 350 applications.
