Old 03-14-2011, 01:45 AM
4onthefloor 4onthefloor is offline
Default "Day2" type BBC Build Up
Im having a 454 BBC Built up for my 1967 Firebird, The Car is "DAY2" style And I want to build the motor to RUN & SOUND the part-So far I have the parts I need for the look-But Im having some trouble as far as Picking a Camshaft-the motor has a Solid Crane powermax roller "nitrous" Grind- 246/254 -114 LSA - 615/636-I had A LOT of issue's with it-So I want to swap it out for a Hydraulic Roller from Howard Cam 242/242 110 LSA
620/620-Also I have 3 Different intakes I can run with this- 1st choice because it looks Cool is the Older Torker single plane that mounts carb at angle, Then 2nd is an equally old Holley "street contender" it is a low riser single plane with a "WINTER'S" Casting mark So it almost looks Factory-Then I have a Modern Edelbrock Performer permashine Dual plane-I also Need some Info On the Best Fit Headers to fit this car-Any Input as far as PROVEN BBC Combo's is appreciated- I had this motor in my Bracket car & Im having it Refreshed- its about 10:5.1 CR- 290 Large oval port heads with large valves heads all done up-BOWTIE Rods-Fully STUDED-Upper&Lowers-& I Want to have it RUN POWERFULL on the street AND strip-its going behind a Muncie 4 speed with 4:33 REAR Cogs..
1967 Firebird 496 BBC Stroker,M22 wide ratio,Thrush Mufflers
Keystone Klassic's with Big&Little's,High Jacker Air shocks.
