Old 01-06-2011, 12:56 AM
al8apex al8apex is offline
Default Craigslist rant about the Deuce Nova here in Phx
http://phoenix.craigslist.org/nph/cto/2144997011.html
Re:1970 Yenko Nova,Real or Clone? - $135000 (Way Too much)
Date: 2011-01-05, 10:34AM MST
Reply to: [email protected] [Errors when replying to ads?]
The Yenko big-block Nova was Produced in 1969 and the small-block-inspired Deuce debuted in 1970. The first-year Yenko's numbered 37, of which 28 had a 427 installed by Yenko's crew and 9 left the lot with the factory-installed 375-horse 396 powerplant. They were 396 cars with no SS emblems.Yenko Novas were available with either the close-ratio Muncie four speed with Hurst linkage or a Turbo Hydra-matic with Hurst Dual-Gate shifter, mated to a heavy-duty 4.10:1 12 bolt Posi axle.
1970 Yenko decided to install a Camaro Z28 LT1 with 360 houses, solid-lifter cam, F-41 suspension and a choice of manual or automatic transmission. 175 versions of the Deuce were built under COPO 9010 and offered in one of eight unique colors. Each car came stock with standard-grade black interior and a front bench seat.
This information was found on Nova History. Again, Your car has the wrong shifter, get rid of the wrong column, please spend the extra $200.00 for a floor shift column. Then change out the shift indicator on the dash to a blank, another $40.00. Then it should look correct, does it have a rear sway bar? Again, Is the vin number correct, tell us the first 5 digits on your ad, you got a 33% chance since they made those cars with either a 4,6 or 8. For your price, I would seek out a more desirable Yenko Corvette,Camaro or Chevelle before buying the Nova version. The only less desirables would be the Corvair and Vega stinger.
Jim R
Scottsdale, AZ
Old 01-06-2011, 02:22 AM
Default Re: Craigslist rant about the Deuce Nova here in Phx
I guess I don't understand the point of this rant [img]<<GRAEMLIN_URL>>/hmmm.gif[/img] I searched the Phoenix craigslist for both 'Yenko' and 'Nova' and found no car like this for sale; only three different rants. Why rant on craigslist about a car that's evidently <span style="font-weight: bold">NOT</span> for sale on craigslist [img]<<GRAEMLIN_URL>>/dunno.gif[/img] I will take a WAG here and say that this may be in regards to the Mist green Nova that runs around metro Phoenix. This car has had its picture taken and posted on this site several times. I doubt that it would fool anyone who's a regular visitor to this site [img]<<GRAEMLIN_URL>>/no.gif[/img]
Bill Pritchard
Old 01-06-2011, 04:26 AM
nova7579's Avatar
nova7579 nova7579 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Bill Pritchard</div><div class="ubbcode-body">I guess I don't understand the point of this rant [img]<<GRAEMLIN_URL>>/hmmm.gif[/img] I searched the Phoenix craigslist for both 'Yenko' and 'Nova' and found no car like this for sale; only three different rants. Why rant on craigslist about a car that's evidently <span style="font-weight: bold">NOT</span> for sale on craigslist [img]<<GRAEMLIN_URL>>/dunno.gif[/img] I will take a WAG here and say that this may be in regards to the Mist green Nova that runs around metro Phoenix. This car has had its picture taken and posted on this site several times. I doubt that it would fool anyone who's a regular visitor to this site [img]<<GRAEMLIN_URL>>/no.gif[/img] </div></div>
X2 [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Old 01-06-2011, 04:35 AM
I know the one that you are talking about Bill....it's the Nickey/Dana/Yenko/Berger/Motion Nova...
Or what the guy really says...it's a Nickey Yenko [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Old 01-06-2011, 05:51 AM
Hmmm... This gentleman is actually describing all the things that make a auto deuce unique. It should have a Hurst auto stick which if you don't know what you're looking at looks like a comp plus 4spd shifter.
The wrong column is the right column. The car was sent from the factory with a column shift. On conversion to the floor, the pin was knocked out, and the handle removed. It was not a smooth column...ever.
As stated above it was an on the column shift, therefore the shift indicator was in the dash. Don, non Hurst never changed, or put the blank in. Auto sticks have the pattern on the top of the shifter ball.
Yes there should have been a swaybar, but many were taken off and had traction bars put on. The important thing is that the swaybar mts are on the bottom of the car. That tells you it's an SS with F41 susp. or a COPO Nova with F41.
Hopefully he will find a real deal bonified &quot;Yenko Corvette&quot;,
and in the process pick his wadded up panties out of his poorly informed a$$.
Old 01-06-2011, 12:09 PM
x  Baldwin  Motion's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Xplantdad</div><div class="ubbcode-body">I know the one that you are talking about Bill....it's the Nickey/Dana/Yenko/Berger/Motion Nova...
Or what the guy really says...it's a Nickey Yenko [img]<<GRAEMLIN_URL>>/smile.gif[/img] </div></div>
Is this in regards to a car that is coming up to auction?
Old 01-06-2011, 03:32 PM
69 Post Sedan's Avatar
I found this Yenko Nova for sale in the Phoenix C/L while lurking.
http://phoenix.craigslist.org/evl/cto/2142096914.html
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">CAR HAS DOCUMENTATION AUTHENTICATING VIN AS A YENKO COPO LT1 DUCE. VIN IS ALSO IN THE SUPERCAR REGISTRY &amp; IS CERTIFIED BY THE COPO CONNECTION. ONLY 1 OF 5 TURBO AUTOMATICS KNOW TO EXIST OUT OF 53 BUILT! FACTORY EQUIPPED COPO 9010 PERFORMANCE PKG., INCLUDING THE 350, 360HP ENGINE &amp; COPO 9737 SPORTS CAR CONVERSION. EXTERIOR IS FATHOM BLUE, 1 OF 53 PRODUCED, BLACK STANDARD 731 BENCH SEAT, TURBO 400 AUTO TRANS., AM RADIO, PWR STEERING, PWR DISC FRONT BRAKES, HURST SPEED SHIFTER, 12 BOLT 4.10 POSI REAR END, DIXCO HOOD TACH, WHITE YENKO STRIPES, DUAL EXHAUST, F41 SUSPENSION, 13/16 FRONT &amp; REAR STABLEIZER BAR, 14X17 YENKO WHEELS, E70 WIDE OVAL BELTED TIRES, SPECIAL EMBLEMS &amp; DECALS, AZ TITLE, ONLY 67,581 ACTUAL MILES! VERY RARE CAR! CONSIGNMENT- CALL 602-697-3503 FOR AN APPOINTMENT.</div></div>
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 01-06-2011, 04:51 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Schonyenko2</div><div class="ubbcode-body">Hmmm... This gentleman is actually describing all the things that make a auto deuce unique. It should have a Hurst auto stick which if you don't know what you're looking at looks like a comp plus 4spd shifter.
</div></div>
X2!!
The car that PostSedan shows sparks my memory a bit - I believe it to be a real car, owned by a collector in AZ but I forget his name. I think he has 2 deuces - or perhaps 2 '68 Gibb Novas.... I forget, but I seem to remember him owning one of the 6 L79 Novas produced in '67! Met him at that Nova Nationals in Belle Terra, IN a few years ago....
Old 01-06-2011, 04:53 PM
and now the owner's son replies:
http://phoenix.craigslist.org/nph/cto/2143835496.html
uninformed person on 1970 Yenko (true car)
Date: 2011-01-04, 3:26PM MST
To the guy claiming the automatic Yenko is a fake....im glad you know so much about this car and have taken the time to check the Yenko Super Car Registery.. In which this car is listed.. I, as the son of the owner of this car ( he in which he owns 29 novas) is very informed on this car...I challange you to prove it wrong in detail with proof.. not just running your mouth thinking you know everything.. This car is part of one of the most elite collections of novas owned by one person...And no the car will not be sold at Barrett.. it will remain in his personal collection, it doesnt need to be sold, unless someone wants to step up with the cash... I will be looking forward to hearing from you... And if you can prove it wrong then Mecheam Auction will have a lot of explaining to do....
You can forward all info to the add...
Thanks for your time
it's NOT ok to contact this poster with services or other commercial interests
PostingID: 2143835496
Jim R
Scottsdale, AZ
Old 01-06-2011, 04:57 PM
and yet another:
http://phoenix.craigslist.org/nph/cto/2132979723.html
1970 CHEVROLET YENKO DUCE, What's Wrong with this Car? - $1350000 (Way Too Much)
Date: 2010-12-28, 12:33PM MST
Before you buy this car, ask yourself, why would this $135,000 over priced Nova have a column shift shifter stub still there with the automatic indicator under the speedometer. The shifter is on the floor with an automatic, never made by GM with a bench seat. Yes, they made 3 or 4 speeds with a bench seat but NEVER an automatic. I would pay the extra money to have it professional inspected, if its for real, it should have the correct fuel lines and chamber exhaust system that all Yenkos had. Now, the best part ever.....special Vin, there are only 3 for the Nova 2 door, either the V8, 6 or 4 cylinder motors. It would have looked like this 111270100001 for 4 cyl, 113270100001 for 6 cyl and 114270100001 for the V8. So what is the vin number for this special Yenko? Why is this not in Barretts auction next month....
PostingID: 2132979723
and another trying to &quot;cash in&quot; on the activity:
http://phoenix.craigslist.org/nph/ctd/2090179118.html
1972 CHEVROLET NOVA
$34,991
PRICE DOESN'T INCLUDE TAX, TITLE, AND LICENSE
Year: 1972
Make: CHEVROLET
Model: NOVA
Engine: V8
Cylinders:
Transmission: AUTO
VIN: 1X27D2L162288
Stock: L162288
Title: CLEAR
Interior: BLACK
Exterior: RED
Warranty: Unspecified
Mileage: 88667
DESCRIPTION
A majority our business is with clients that are out of state and satisfaction is essential. The condition of each of our vehicles are guaranteed and put in writing. Buy with confidence knowing your getting a vehicle we are going to stand behind! All of our cars are kept indoors and shown by appointment only. To view a complete list of inventory please visit hubbardautocenter.com. Please contact Mark Hubbard @ 480-318-2277 for more information.
Please feel free to call us for a walk around description as well as a driving description. Our reputation is very important to us and our wanting every customer to be pleased with their purchase is our #1 GOAL. Please feel free to contact us for any questions or concerns that you might have at the following numbers. Please be advised that these cars are pre-owned and probably have small dings, scratches or paint imperfections.
Due to space limitations please call for your detailed walk around descriptions at 480-318-2277
If you purchase this car without calling for a walk around description no refunds or price adjustments will be made. You may ask for Mark Hubbard.
OPTIONS
Please call us for information regarding options on this vehicles.
CONTACT US
Hubbard Auto Center
Scottsdale, AZ
Mark Hubbard
Phone:
Toll-Free Phone: 480-318-2277
Jim R
Scottsdale, AZ
