Old 12-26-2010, 11:01 PM
Default Holley base plate ID needed
I recently purchased a 3310-1 and it had the wrong base plate. The cast numbers are 2R4233F and there are no stamped numbers on it. Does anyone know what carb models this went on?
Martin
Martin Foltz
68 Camaro SS-396
Old 01-09-2011, 01:18 AM
Default Re: Holley base plate ID needed
I finally had time to take a couple photos. Throttle plates are 172s.
Martin Foltz
68 Camaro SS-396
Old 01-09-2011, 02:46 AM
VintageMusclecar's Avatar
Looks like an early 3310 "EH" baseplate. The 3310-1 used a different casting with a flat machined boss on the pass. side rear corner that can be drilled to accept a PCV tube like the `66-`72 style 780's.
Old 01-09-2011, 03:04 AM
Thanks, I have a correct 3310-1 baseplate stamped 33101. It has the flat boss that you mention and a vacuum port out the rear. I'll just rebuild with that one and plug the rear.
Martin Foltz
68 Camaro SS-396
