Old 12-19-2010, 05:40 PM
Donnie's Avatar
Donnie Donnie is offline
Default need opinions cowl plenum
what are your thoughts about putting a cowl plenum air cleaner on my 69 L78 Chevelle when I get it finished?
I really like the look just not sure about cutting the hole in the firewall. need opinions, do you think it will hurt the value of the car?
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 12-19-2010, 05:48 PM
BARRY BARRY is offline
Default Re: need opinions cowl plenum
NO you will regret it
Barry Allan
Old 12-19-2010, 06:05 PM
nova7579's Avatar
nova7579 nova7579 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: BARRY</div><div class="ubbcode-body"> NO you will regret it </div></div>
Why will he regret it?? I think they are very cool.
Brian
Old 12-19-2010, 06:16 PM
al8apex al8apex is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Donnie</div><div class="ubbcode-body">what are your thoughts about putting a cowl plenum air cleaner on my 69 L78 Chevelle when I get it finished?
I really like the look just not sure about cutting the hole in the firewall. need opinions, <span style="font-weight: bold">do you think it will hurt the value of the car?</span> </div></div>
yes it WILL hurt the value of your car, ASSUMING your car is stock/original
IF your car is a &quot;street mod&quot; or the like (ie, NOT STOCK) it will not likely affect the value, HOWEVER some one may want to return your car to &quot;stock&quot; and would not appreciate carved up sheet metal
Jim R
Scottsdale, AZ
Old 12-19-2010, 06:43 PM
Don_Lightfoot's Avatar
Don_Lightfoot Don_Lightfoot is offline
I was actually thinking the same thing last year Donnie. I feel they are definitely cool and would be a unique addition to my car. However, a few things made me forget about it:
1) - Finding a &quot;correct&quot; one for a 69 Velle as there were many of these available for different models.
2) - Cutting firewall.
3) - Costs involved to get one absolutely correct.
4) - I assume there would be some other minor issues regarding certain wire and hose routings as well.
Good luck with your decision.
Specialized Chevrolet Decals
Old 12-19-2010, 07:49 PM
greg5436 greg5436 is offline
a guy is repoping them now for 650.00 on team chevelle and ebay.someone did a little smoothing on the firewall of my 69 conv. so i found an original one and installed it.i did cut out the firewall and put it on like it should be installed.when the top is up you can hear it sucking air inside the car.i just happened to have another all original one for a 69 chevelle sitting on the shelf.still has original staples and rubber.my engine compartment gets alot of attention from that air cleaner.it's a part that you would never take off once installed.also you can cut out the bottom of the fiberglass duct and not touch your firewall. greg
Old 12-20-2010, 01:56 PM
Woj's Avatar
Woj Woj is offline
Donnie,
I was thinking the same thing as Greg. No harm done that way and you can change it back to the open element when you want.
Phil Woj.
Old 12-20-2010, 03:08 PM
I don't think it will hurt the value. I would put it on. In fact, I put a cowl plenum crossram air cleaner on a 67 Z28 years ago and it probably helped it's value.
Old 12-20-2010, 04:11 PM
olredalert olredalert is online now
----I put a repop 67 Camaro cowl plenum air cleaner on my 65 Chevelle wagon, and I love it! Cool thing was that my wagon came with factory AC and I had removed it for aftermarket AC. That left the factory hole and it matched up with the cowl piece like it was made that way from the factory. With that said, my wagon is sort of a loosly wrapped pro-touring style and I wasnt bothered by cutting holes if I had to in the least.......Bill S
Old 12-21-2010, 02:38 AM
69RSZ 69RSZ is offline
If cutting the firewall is a problem dont do it,just use some washers on the bottom screws on the duct to let air into the plenum.
Ron C.
67 RSZ/28
67 Z/28
71 SS LS5 chevelle
