Old 11-25-2010, 03:27 AM
firez firez is offline
Default 1968 Z28 cowl plenum smog tubes
Were smog tubes on a cowl plenum car the same as on a open element breather car?
1968 LOS Rallye Green Z28
Old 11-25-2010, 09:13 PM
allcamaro's Avatar
allcamaro allcamaro is offline
Default Re: 1968 Z28 cowl plenum smog tubes
The drivers side is but the passenger side takes a hard turn to the front on the engine to miss the bottom of the air cleaner.
1967 Nova SS L30
1967 Chevelle L79
1969 RS Z/28 Red
1969 RS Z/28 Lemans Blue
1970 Z/28 Blue
1967 RS Convertible
1968 Camaro SS
1992 GMC Yukon 30166 miles
Old 11-25-2010, 09:43 PM
302moz 302moz is offline
Use the original tube,but replace the rubber hose with a 90 degree bend. John p.s. That is what I plan to do when the time comes.
Old 11-25-2010, 11:02 PM
That sounds like a good idea,I have been told a certain Nova smog tube will work but just more money
Old 11-26-2010, 12:55 AM
allcamaro's Avatar
The tube will still hit the bottom side of the breather, been their and done that, be better to get a different tube.
1967 Nova SS L30
1967 Chevelle L79
1969 RS Z/28 Red
1970 Z/28 Blue
1967 RS Convertible
1968 Camaro SS
Old 11-26-2010, 04:31 AM
firstgenaddict's Avatar
If you use a 69 pass side tube it bends 90 deg before the valve screw on. Not correct (obviously) however it should work.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 11-26-2010, 11:06 AM
I can not hink why GM would not have made a camaro specific one for this application
Old 11-26-2010, 02:53 PM
bluel78 bluel78 is offline
Im still learning but I would think the tube would be the same. The cowl plenum was an over the counter piece/ dealer installed and did'nt come with a smog tube. They probably assumed if you installed the cowl plenum setup you would also buy headers, therefore no interference with the smog tubes.
Old 11-26-2010, 03:26 PM
Plan b shorten the tube.Then the check valve will be lower. Send it to Bill and have it replated. John
Old 11-28-2010, 09:34 AM
jack hatch jack hatch is offline
I have a set of smog tubes that I acquired from Jerry MacNeish years ago. The passenger side tube is rare and built specifically for the Cowl Plenum installation.The passenger side tube sweeps 90 degreees in the direction of the tube itself pointing to the smog pump. It also starts its sweep at the firewall end of the tube to allow room for the hose to connect to the smog pump The drivers side is the same.
