Old 11-15-2010, 05:24 PM
Default Source for Aluminum Plugs For BBC Aluminum Heads
Does anyone know of a source for the plugs that screw into the early closed chamber BBC factory aluminum heads? Were they used in other applications?
Old 11-16-2010, 02:08 PM
69L72RS 69L72RS is offline
Default Re: Source for Aluminum Plugs For BBC Aluminum Heads
Jason,
You might try to match one of the plugs from McMaster-Carr.
http://www.mcmaster.com/#aluminum-pi...-plugs/=9qr1yf
Hope this helps.
Eric
Old 11-16-2010, 04:18 PM
I will give them a try.
Thanks!
Old 11-16-2010, 04:41 PM
OK, I ordered some 1" plugs. I will post some pictures when they arrive.
Old 11-18-2010, 02:36 AM
The plugs came today. They look very good. A little tuning will be needed to make them look as original but very nice for generic units.
Old 11-19-2010, 05:05 AM
After a quick filing of the outer edge and glass bead blast:
Old 11-19-2010, 05:11 AM
Looks great Jason...
Old 11-19-2010, 05:39 AM
Thanks, for those interested they were about $6 each from McMaster-Carr. They would work well to make 074 or 077 heads look earlier externally. Although the exhaust ports and snowflakes look different on earlier heads, I think most just look for the plugs. Good idea for a clone since the open chamber heads are generally better performers.
