Old 11-06-2010, 05:43 AM
Alabamcam Alabamcam is offline
Default 1968 L35 RS/SS Camaro Convertible
Selling my 1968 RS/SS L35 396 low (61K) original mile Camaro with factory VIN stamped TH 400, 12 Bolt Rear, <span style="color: #33CC00">Ralley Green</span>, White Convertible, White Parchment Interior with PS, PT, Power drum brakes, and center clock console. Fresh rebuilt 396 and TH 400, original carb comes with it but ordering replacement carb. or can send original carb. to Eric. The Camaro is all original body panels, excellent survivor White Parchment Interior, all original engine components including original GM factory drive belts with part numbers, hose clips, plastic wire ties, original heavy duty radiator, factory dual exhaust with resonator except block is factory replacement resurfaced bored 30 over 323 J dated block. All original factory perfect date coded (B14 two weeks from body production 4th week of Feb.) Heads, Intake, 169 Dist, Alt., etc... The previous owner over sprayed original paint with yellow primer, however rear black seal panel is visible and shown in attached pictures. The Camaro will require paint, tires, new top installed, small detailing and carpet. The Camaro is very clean, truly rust free body, frame, and rust free trunk (original speckled paint), that appears to be life time garage kept, (would be near survivor condition without primer over sprayed). I have new heavy weight but correct white top, original and NOS 396 emblems, NOS side marker bezels, a few other NOS or other original parts, and excellent original grille. I would consider some 1967 NOS L78 or Z/28 Camaro parts as partial payment. PM or call David 706-360-2651.
<span style="color: #33CC00">$33,000</span>
1967 IPC 4P -
1967 RS Z/28 4L
1967 RS/SS 4K
