Old 11-02-2010, 05:20 AM
MosportGreen66's Avatar
Default Sottering a plate frame? Need help
Hey Gents,
I need your brilliant minds. Bought a vintage plate frame that cracked in transit. I need to make this thing whole again - what are your suggestions?
Here are the photos.
Old 11-02-2010, 06:00 AM
Default Re: Sottering a plate frame? Need help
Pardon the misspelling... Soldering is what I was aiming for.
Old 11-02-2010, 02:27 PM
m22mike's Avatar
m22mike m22mike is offline
Unless someone knows of some space are trick, I do not think you can repair that crappie pot metal that way... [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
I would make a aluminum stiffener patch that fits the back of the frame snugly between the formed edges and extends about 1 to 2&quot; beyond the crack on both sides.
The little stiffener patch only needs to be around .020&quot; , even a piece of roof flashing might work, something not to thick.
Sand the bottom of the patch and the area of the frame to create some bite for some good epoxy.
On the patch drill a series of # 30 / 1/8 holes so the epoxy has more more area to hold onto. Back up with a paint stick and clamp till dry. And then be gentle with it. Might work.
Mike
Old 11-02-2010, 02:52 PM
kwhizz kwhizz is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: m22mike</div><div class="ubbcode-body">Dan
Mike </div></div>
What he said!!
Old 11-02-2010, 03:00 PM
Thanks a lot guys! I'll get working on it.
Old 11-03-2010, 12:04 AM
m22mike's Avatar
Make sure you show us your work...you'll be graded .... [img]<<GRAEMLIN_URL>>/grin.gif[/img]
Old 11-03-2010, 01:54 AM
No shot I trust myself to do this... Its being farmed out because I'm a wimp.
Sorry Mike... haha.
Old 11-03-2010, 03:30 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: MosportGreen66</div><div class="ubbcode-body">No shot I trust myself to do this... Its being farmed out because I'm a wimp.
Sorry Mike... haha.
Dan </div></div>
LOL...c'mon Dan! [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Old 11-03-2010, 01:02 PM
x  Baldwin  Motion's Avatar
Dan, you can do this, I reccomend &quot;marine tex&quot; as the epoxy of choice. Good Luck.
[img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 11-04-2010, 06:16 AM
mbxlesney mbxlesney is offline
Hi Dan.....I have had a simular incident and these guys may be able to solve your problem. http://www.muggyweld.com/potmetal.html
They have videos you can see how the process is to repair pot metal and other diecast items. You have to buy their rods and flux but you can use a propane torch if you do not have a welder. Their rods can be used to fill pits in pot metal also. Hope this helps. Kim
Kim
1970 Nova Fathom Blue L78 M21 3:55
1970 Nova Classic White 454HO THM400 4:10
