Old 10-22-2010, 12:45 AM
Glenn L78's Avatar
Glenn L78 Glenn L78 is offline
Default BB CAMARO SPRINGS
HOW CAN I TELL THE DIFF BETWEEN BB AND SMALL BLOCK FRONT SPRINGS? BY HEIGHT? COIL SIZE? I HAVE A NEW SET OF SPRINGS
WITH NO NUMBERS THAT ARE SUPPOSE TO BE FOR A BB. THANKS
69 CHEVELLE SS L34 4SP BENCH ALL MATCH
68 CAMARO L78 4SP 4:10 born with everything
66 Pro Street Nova
41 Willys Nostalgia Gasser
66 corvette 427/390 # match
Old 10-22-2010, 01:38 AM
markjohnson's Avatar
Default Re: BB CAMARO SPRINGS
That's a good question and it would be nice to see a chart with the springs' general height while with the spring removed and sitting on the ground and also a measurement the wire diameter with a set dial calipers. I couldn't believe how the ride height of my old Camaro changed when swapping from a ZZ4 Small Block to an iron-headed BBC. I expected it drop somewhat but was still surprised at how drastic it was! Does such a chart exist?
Old 10-22-2010, 03:25 AM
Glenn L78's Avatar
NOT THAT I KNOW OF,I DIDNT TAKE OUT THE OLD SPRINGS YET BUT THATS NOT FAR OFF. I HAVE A 68 CAMARO L78 WITH 20K ORIGINAL MILES 2 OWNER THAT IM ABOUT TO DISASSEMBLE. I HAVE WHAT IS SUPPOSE TO BE A NEW SET OFBB SPRING FROM ANOTHER PROJECT THAT I WOULD LIKE TO USE IF I CAN VERIFY
66 Pro Street Nova
Old 10-22-2010, 04:30 AM
x77-69z28's Avatar
Shhhh stop yelling
Old 10-22-2010, 06:23 AM
I've been able to ID springs before using David Pozzi's chart. Also check to see if there is a number stamped on it, usually somewhere on the end coil.
http://www.pozziracing.com/Media/spring_chart.jpg
TheMuscleCarGuys.com
Old 10-23-2010, 04:03 PM
Glenn L78's Avatar
sorry
66 Pro Street Nova
Old 10-23-2010, 04:04 PM
Glenn L78's Avatar
Thanks,that will be of help
66 Pro Street Nova
Old 10-23-2010, 06:07 PM
leave the originals in unless they are real bad. JMO
Old 10-23-2010, 07:27 PM
BillD BillD is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: [email protected]</div><div class="ubbcode-body">leave the originals in unless they are real bad. JMO </div></div>
I agree. Keep the originals if you have them. I have never found a set of repro springs that let the car sit properly.
Old 10-23-2010, 07:43 PM
Glenn L78's Avatar
Your probably right, there is nothing wrong with the springs I just thought I would replace them during the resto
66 Pro Street Nova
