Reply Price $ Update Bump Mark Sold
Old 09-23-2010, 04:56 AM
Guest
Posts: n/a
Default 572 BBC Pump Gas Engine - Custom
All-new 572 cubic inch big block Chevy for sale. It is <span style="text-decoration: underline">not</span> a GM crate motor. It is built with all new high end components including a CNC-machined Chevy tall deck bow tie cylinder block, GM Performance Parts (Callies Racing) 4340 crankshaft, ATI harmonic damper, GM Performance Parts (Manley) H-Beam connecting rods, Clevite bearings, CP flat top pistons, CP wrist pins, 0.043-inch Hellfire/low drag ring package, Crane 0.737/0.726 lift mechanical roller cam, Crane Gen VI mechanical roller lifters, Jesel Belt Drive, Brodix -3 “xTRA O” CNC-ported cylinder heads (424 + CFM @ 0.700 valve lift), matching Brodix single plane intake manifold, Brodix-Comp Cams titanium retainers, Brodix-Comp cams springs, valve locks and small parts, Holley 80672 1050 Ultra Dominator carburetor, Jesel shaft rockers, Titan G-rotor oil pump, Titan oil pump hex drive, custom Stef's oil pan, ARP fasteners, MSD electronic distributor (slip collar), MSD wires. The big block has been built to run on pump gas and will easily handle a 250 HP shot (approximate) of nitrous. Basically, this is an extreme power, reliable street-capable engine. I’m asking $15,950 Canadian for the engine (carb to pan), which is less than the cost of the parts. Everything is new and never fired.
Can be inspected/purchased without heads, intake or pan installed (but obviously included).
Engine is located on Vancouver Island. I can deliver to the BC lower mainland or local Canada/US border crossings.
Some folks have asked and yes, I'll separate the engine as a shortblock (including everything from the roller lifters to the Titan oil pump and from the ATI balancer back). The price is $9250 OBO (Canadian). Its a screaming deal if you want to go fast (real fast).
Thanks Yenko.net!
Wayne
