Old 08-26-2010, 03:50 AM
Default Rust remover - more amazing uses!
Most of you probably remember when I found this stuff and used it to clean the surface rust from the entire underside of my Trans Am: https://www.yenko.net/ubbthreads/ubbt...78&page=26
Well, since I'm done with the T/A I decided to get the old Project Pit Viper cleaned up since it has been sitting for 10 years in the garage serving as a work bench/parts storage rack for at least the last 6 years.
I needed to get the rusty rotors cleaned and didnt want to just drive them to scrape the rust off. So I pulled the wheels and rotors and then soaked the rotors in the safest rust remover liquid. It was amazing. In just over 15 minutes the rust was gone. The key with this stuff is to get an aquarium heater and let it heat up the liquid to 70 or 80 degrees. The rust just dissolves away.
Here are the rotors before:
and while soaking:
And after about an hour:
Here is the website for the place. They are here in New Jersey. This is where the Oklahoma Time Capsule 57 Plymouth is currently being derusted. I saw it while I was up there the other day.
http://www.safestrustremover.com/
