Old 07-23-2010, 03:35 AM
BARRY BARRY is offline
Yenko Advertising Member
Default ZL1 SPARK PLUGS
HI what are the best spark plugs for a 1969 zl1
Barry Allan
Old 07-23-2010, 03:57 AM
William William is offline
Default Re: ZL1 SPARK PLUGS
Standard plug was AC R43XL.
Old 07-23-2010, 02:57 PM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
I use AC R43XLS. Extended tip is the difference. The ZL-1 cam eats plugs, so I change them offen.
Old 07-23-2010, 04:47 PM
Chevy454 Chevy454 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 69SSZL1</div><div class="ubbcode-body">I use AC R43XLS. Extended tip is the difference. The ZL-1 cam eats plugs, so I change them offen. </div></div>
If you're not after that &quot;nostalgic&quot; look, and are looking for a better plug than the AC, try an NGK...the NGK site says the standard plug is the BR5ES, which would be an R6918B-7 in a racing plug...someone might wanna double check those numbers, as I'm kinda in a rush this morning!
