Old 07-07-2010, 02:55 AM
Default 3933198 ZL1/L88 GM Aluminum Intakes
1-4 are left to right on the top row. 5-8 are left to right on the bottom row. All intakes are raised pad 3933198 Intakes, not ground and stamped. All intakes have all markings intact.
1) Dated 1/14/68, No porting or corrosion, One
outer runner mounting point welded. $500
2)Dated 8 or 9/16/68, no porting or corrosion, heater outlet nicely repaired(should not show with nipple installed. $600
3)Dated 2/7/68, Milled, Ported, Repairs at 2 front outer rummer mounting points, Looks nice. $350
4) No cracks or repairs. No porting or mods. Finish is dull. Needs to be reblasted or reskinned. $650
5) 1/5/68 Modified plenum(filled back in), some porting, no repairs, Negligible corrosion in rear coolant block offs. $600
6) 1/5/68, 2 runner repairs by me(need final blending and blasting, very nice intake overall. $500
7) 8/6/70, No cracks or repairs, 2 small plugs in rear cooling ports. $550
8) 1/4/68, cracks at both driver's outer runner mounts(repaired inside runners, heavy corrosion around thermostat and in cooling ports. Looks good, but needs welding. $400
