Old 06-02-2010, 02:24 AM
68bird400HO 68bird400HO is offline
Default SS wheel charcoal paint Qs
I am restoring a set of Pontiac rally wheels and am having a difficult time matching the charcoal color in the five inserts. The PPG Duracryl Lacquer part number is DDL-32947, however, I can't find any paint supply places that can mix it anymore. It is an odd color since it has a slight hint of blue to it. Here is the mixing formula:
Mixing formula:
Color Units (cumulative)
384 Yellow 20
311 White 44
321 Blue 74
358 Black 224
349 Poly 694
DX 265 Flat 984
First, I was wondering if anyone knows if this is the same PPG number used on the Chevy SS wheels for 1970-72 (or there abouts).
Second, if it is also the chevy color, has anyone found a close match to it off-the-shelf? I see that there is a chevy charcoal grey spray paint available from the vendors like D&R which is a Seymour product. Has anyone tried that?
Old 06-03-2010, 03:03 AM
DannyD DannyD is offline
Default Re: SS wheel charcoal paint Qs
I have a quart of PPG Duracryl DDL. This is Acrylic Lacquer with the following on the label:
3296 (Prime)
OEM Code: WOE4074
Dark Gray
This paint has a texture to it when it dries. I used it on my 72 El Camino SS and I was satisfied with the result. I did a lot of research and came up with this product. I can send you a picture of them if you like. Dan
Old 06-03-2010, 03:43 AM
wheelhop wheelhop is offline
Call D&R and ask for steve (the owner). He will tell you what the correct color is and send it to you. I don't think it's called charcoal grey.
