Old 05-21-2010, 04:49 AM
69 Post Sedan's Avatar
Default Oil Pump Question
I have a good used Moroso oil pan and it has the correct press in pickup. I am running a Extreme Energy XR274R solid roller cam. Comp Cams told me NOT to run a High Pressure Pump and to make sure it is "Anti-Cavitation".
My question, will the Moroso 22162 pump work for my application? http://www.summitracing.com/parts/MOR-22162/
If not...any suggestions?
Thanks, Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 05-21-2010, 05:40 AM
PxTx's Avatar
PxTx PxTx is offline
Default Re: Oil Pump Question
That sounds right.
Moroso's blueprinted racing oil pumps feature anti-cavitation slots and enlarged feeder grooves that are ball-milled smooth, providing steady oil flow to each side of the gears for high-rpm lubrication. They feature a Parkerized coating that retains oil for extra lubrication during break-in and cold starts. The included intermediate shafts are manufactured from SAE 4150 chromemoly steel, with a slot drive for positive engagement and to withstand high-rpm operation. Each pump is individually tested to ensure proper functionality.
Paul III
Old 05-24-2010, 06:54 AM
Thanks Paul. I am going to contact Moroso and see if that one will work.
Kurt
