Old 05-05-2010, 03:12 PM
ted ted is offline
Default 7/16ths connecting rod bolts ..
Good morning!! Are there any differences between Boron 7/16ths L88 and Zl1 bolts versus LS6 Borons?
Thanks in advance.
Old 05-08-2010, 04:53 PM
ted ted is offline
Default Re: 7/16ths connecting rod bolts ..
Maybe a re-phrasing of the question is in order. Are all stock 7/16ths dimple connecting rod bolts "knurled" about a half inch below the head. I read somewhere that the LS6 bolts had this knurling and were stronger than the earlier ZL1 and L88 units.
True or Not?? That is the question.
Thanks!
Ted
Old 05-08-2010, 09:10 PM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
Not true, the Boron Steel bolts are the strongest. They have a ground shank which is stronger than knurling.
Old 05-09-2010, 01:53 AM
Adding boron to steel alloys is an inexpensive and potentially dangerous method of achieving higher tensile strength. Boron is not allowed in either grade 5 or grade 8 fasteners according to SAE. Fasteners containing boron must be marked Gr 5.2 or 8.2 on diameters under 1-1/2". Cap screws containing boron are prone to stress-relaxation failure which can be increased when used in high temperature cyclic environments.
Proper knurling should not weaken the clamp load as long as the fillet radius (where head meets shank)is not damaged during the upset.
Howard
Old 05-16-2010, 02:03 AM
ted ted is offline
Thanks guys! I was under the impression that ALL 7/16ths dimple rod bolts were "Boron" types and then broken down further into GM "knurled" versus GM "non knurled".
Again 'merci encore' for the explanation SouthLake Texas.
Ted
