Old 05-03-2010, 01:30 AM
Alss's Avatar
Alss Alss is offline
Default Off idle sneeze
Been having a issue with the ZL-1 in my Malibu. ANything under 1500 RPM anb a good stab of the throttle will result in a misfire thru the carb. I need to gently roll out of the hole then stab the throttle. Timing is 19 initial, 18 in the dist. ALso will sneeze when you slow down and then get back into the throttle easy. Any ideas?? already have installed new plugs, new oil, Eric just did my carb, MSD dist new wires..HELP!!
thanks
ALbert
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 05-03-2010, 01:35 AM
VintageMusclecar's Avatar
Default Re: Off idle sneeze
ALbert;
I never heard back from you on Friday. What did you come up with on the trim screws?
Call me tomorrow afternoon and I'll try to help you get this thing dialed in.
Eric
Old 05-05-2010, 02:43 PM
Get her Dailed-in for Music City Dragway!
Old 05-05-2010, 02:51 PM
Alss's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body">Get her Dailed-in for Music City Dragway!
Dan </div></div>
Im trying...she aint co-operating [img]<<GRAEMLIN_URL>>/mad.gif[/img]..Ill be back on it on Friday..eric has given me some input for adjusting the carb..so well see what happens. Hydroboost is in..rear control arms and sway bar are done..shifter is in (floor)4 more weeks [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 05-12-2010, 06:06 PM
Alss's Avatar
OK...got her running good now!!..first time I have felt the converter when the car leaves [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]..problem wound up being that the carb..a 850DP is just too big for the little 427..went to a smaller 750DP and it runs real good..thanks to all that offered help and opinions
Dan..ready for Music city!! [img]<<GRAEMLIN_URL>>/naughty.gif[/img] [img]<<GRAEMLIN_URL>>/[/img] [img]<<GRAEMLIN_URL>>/[/img]
