Old 04-12-2010, 06:04 PM
jasonL78 jasonL78 is offline
Default 68 -72 nova rear wire wrap/ Shifter tunnel
I have a complete 68 nova rear tail light wire wrap. This protective wrap goes from under the front of the dash to the rear tail lights. It protects the rear wire harness. The harness is included but someone has spliced all the light sockets? So if you need the harness it will need to be repaired. Looking to get 75.00 for it
I also have a transmission tunnel that I am going to remove form the 68 nova I am working on, going with a full floor pan. I was thinking someone might be able to use it if your 4 speed shifter hole needs to be repaired. If interested I can take a picture of what I have to see if it will work for you. Looking to get 35.00 for it.
Thanks Jason
Old 04-13-2010, 04:58 AM
Default Re: 68 -72 nova rear wire wrap/ Shifter tunnel
Pictures of the tunnel I think it would be the same as camaro?
