Old 04-09-2010, 05:10 PM
Benl Benl is offline
Default Correct Master Cylinder/Booster 1971 Nova
I am looking to put power brakes on my 1971 Nova. I want to keep it original, so i thought this would be the place to ask my question.
As I am looking at all the options, I am not sure what is the correct combination. My car has front and rear drums, and an externally stock smallblock. It was originally manual brakes.
The following are the things I was wondering about.
9" or 11" booster
squared off or rounded master cylinder
Master cylinder with bleeders or not
anyone else done this conversion? what else do I need, it seems there is a bracket that mounts on the engine to hold the vacuum hose, a new vacuum fitting for the intake manifold and the check valve and vacuum hose kit.
I have been looking at ground up's products.....any caveats on them. I have had good experience with their other products so far, but thought I should check.
again I want to keep it looking factory, and I'm just not sure what is correct. Any help you guys can provide on this would be great.
Thanks guys
Ben
Old 04-10-2010, 06:46 AM
Mr. Chevy's Avatar
Default Re: Correct Master Cylinder/Booster 1971 Nova
Ben, go with an 11 inch booster, and the master will be the squared off type w/bleeders, not round like a "309". As for the conversion kits, I think they are similar. However, I never did one.. I personally don't care for Ground Up I have had bad experiences w/them. I would check National Nostalgic Nova's website. I know they have this stuff plus if you have a tech. question you can ask them directly and get someone on the phone that knows a little more than just a parts salesperson...
Just my .02 Hope I was of some help... Rich
Old 04-10-2010, 06:47 PM
Good advice...wilma
