Old 03-22-2010, 04:36 AM
x  Baldwin  Motion's Avatar
Default Decode TRW 21699 Piston / engine combo
where can we decode these TRW 21699 piston numbers ?
the block is 14016379 4 bolt
heads 3991492
crank 3941182
Old 03-23-2010, 01:23 AM
Default Re: Decode TRW 21699 Piston / engine combo
any TRW clues? anyone? Bueller? Bueller?
Old 03-23-2010, 07:27 AM
beater68427 beater68427 is offline
A little odd number there, No letter code? any oversize? Number actually makes me think it is a goodwrench from the mexican cartel era....
Old 03-23-2010, 01:37 PM
Thanks Jeff. that's all I could see on the underside. The pan is now buttoned up. I've been led to believe it could be from the early 70's and has a domed top and must use short plugs.
Old 03-23-2010, 04:38 PM
I see would need the number from the top of piston. That Block with a 14 and 8 digit would be a late 70's the crank number is missing a number should be 39411182 Steel crank number used in truck all years with 2pc seal and I believe in early Z28. The 492's are angle plug I believe. Sounds like someone used a late 70's 4 bolt truck engine to start with.
Old 03-23-2010, 08:05 PM
