Old 03-19-2010, 03:21 PM
dlv4540 dlv4540 is offline
Default 1968 396-375HP MQ Coded Shortblock
I have a 1968 396 4 bolt block casting number 3935440 dated E-21-8 with front pad stamped T0524MQ 18N449843. The block is standard bore with two sleeves and has been cleaned, magged and pressure tested good. It also has one chip down by the outside starter bolt. I have with it a standard factory set of 402 11 to 1 pistons mounted on 3/8 dimple rods along with a 20 under 6223 crankshaft that are balanced together. The crank will polish up and the pistons will just need a set of rings. Will sell package deal for $1850. I also have a set of rebuilt 3919840 heads dated F-17-8 and F-18-8 for $1500. Can ship if you cannot pick it up. 330-770-2517
Dennis Vugrinovich
Old 03-19-2010, 08:42 PM
x77-69z28's Avatar
Default Re: 1968 396-375HP MQ Coded Shortblock
why dont you list it on the crg site in the orphans section. maybe we can get it back in the orig car!
Old 03-20-2010, 02:12 AM
I'm all for that one. Thankyou for the advice and maybe someone can attach a memo on their to this posting.
Dennis Vugrinovich
Old 03-20-2010, 05:49 PM
69 Post Sedan's Avatar
Done
http://www.camaros.org/forum/index.php?topic=5960.0
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 03-20-2010, 09:00 PM
Thankyou for your help.
Dennis Vugrinovich
