Old 03-06-2010, 04:59 PM
Default L72 Part numbers
Does anybody have to share or know where to find a complete listing of all the part numbers for the L72 from 69?
Old 03-06-2010, 10:17 PM
69L72RS 69L72RS is offline
Default Re: L72 Part numbers
L-72 PARTS
DESCRIPTION PART NUMBER CASTING AND IDENTIFYING NUMBER
780 HOLLEY CARBURETOR L-72 3959164 3959164 GE (STAMPED ON AIR HORN)
ALUM. INTAKE MANIFOLD L-72 3933163 3933163 WINTERS CASTING (CLOSED DIVIDER)
HEADS- CAST IRON 3919839 3919840 SQUARE PORT-CLOSED CHAMBER
BLOCK- CAST IRON 3963516 3963512; 4 BOLT MAIN
CAMSHAFT 3863143 141 STAMPED ON END; CHAIN DRIVEN
DISTRIBUTOR-ALUMINUM 1111499 1111499 STAMPED ON SHAFT
COIL 1877306 429BR (w/ 8400 & 8418 STARTER)
PUSH ROD GUIDE PLATES 3860038 3/8"
INLET PUSHRODS 3946067 3/8"
EXHAUST PUSHRODS 3946069 3/8"
ROCKER ARMS 3959182 H STAMPED L-72 ENGINES MAY HAVE "L" ARMS
PISTON (STD.) 3888342 3888304 CAST INSIDE PISTON- TRW
CONNECTING ROD 3856240 3/8" BOLTS BUMP ON SHAFT
VALVE SPRING ASM. 3970627
HEAD GASKET 330860
SPARK PLUG 5612425 AC-R43N
STARTER MOTOR- AUTO 1108788 STAMPED 1108400
STARTER MOTOR- MANUAL STAMPED 1108418
FLYWHEEL 3998281 MANUAL TRANS.-11"
FLYWHEEL 336763 AUTOMATIC TRANS.
BELL HOUSING 621 11" ALUMINUM
LIFTERS 5232695 MECHANICAL
WATER PUMP PULLEY 3947824 3947824 STAMPED BV
WATER PUMP 3931064 3931065 CAST IRON (ALSO 23969811)
HARMONIC DAMPER PULLEY 3955291 3955291 STAMPED AB
HARMONIC DAMPER 3870325
AIR PUMP PULLEY 3932458 STAMPED 3932458
ALTERNATOR 1100837 STAMPED 1100837 CZ
ALTERNATOR PULLEY 3870325 DEEP GROOVE
EXHAUST MANIFOLD-LH 3909877 3909879
EXHAUST MANIFOLD-RH 3919860 3916178
I got this list from somewhere but it has a few missing numbers.
Late built engines would have #291 heads and based on the one owner cars that I have seen I believe the distributor should be a 1112000.
Old 03-06-2010, 10:18 PM
I know it isn't a complete list, but it is all that I have.
Hope it helps.
Old 03-06-2010, 11:10 PM
markjohnson's Avatar
That's a nice list Julian. I'm sure it took you more than a few minutes to put that together and type it up. Thanks for taking the time.
Old 03-07-2010, 01:06 AM
Atuckman Atuckman is offline
very kind of you to take the time.
Old 03-07-2010, 02:45 AM
Thanks Julian, good list. The one thing I didn't see on there is spark plug wires...what are the correct ones?
Thanks again!
Old 03-07-2010, 03:28 AM
All BB's used wire kit #6298190,which included 8 wires & 1 coil wire.
