Old 03-01-2010, 05:23 AM
Musclecarkid Musclecarkid is offline
Default 68 Nova SB Fan / Shroud?
Need pics of a 68 small block Nova fan and shroud set up. We have a 295HP 350 and believe the car has a 69-72 shroud which is a little too far from the fan. Don't think the 68 SB Shroud is currently available. Does the SS350 use a 5 blade fan with a Clutch or Spacer?
Any help is appreciated.
Kevin
1970 Chevelle Droptop
Period Correct Speed Parts
482 BBC, M22 or TH400?
Day 2 Super Stock Rocks
Old 03-01-2010, 05:31 PM
Default Re: 68 Nova SB Fan / Shroud?
Kevin, I have the original shroud off our 68 SS350 car...not positive if it is a 68 unit, but it came with the car. The part number on the shroud is #3919167....there is also a small "c" stamped ahead of the number. I believe the correct fan for the small block, non a/c, would be a 4 blade unit. Hope this helps...tom
Old 03-01-2010, 06:27 PM
Does the 4 blade use a fan spacer? If so, what length? Can you send pics of the SB Fan Shroud?
Kevin
Old 03-02-2010, 02:18 AM
I think the fan is still on the motor...will check and get back to you. I'll have to take a few pics of the shroud.
wilma
Old 03-02-2010, 06:21 AM
Thanks Tom, Post pics or email them to me.
Kevin
Old 03-02-2010, 10:21 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Yes, the 4 blade fan uses a spacer. I believe it is a 1.5 inch spacer.
standard fan - 3927791 is a 4 blade fan, you would also need the 3927792 spacer with that fan.
Old 03-02-2010, 10:32 PM
Thanks, Still looking for a 68 Nova SB Shroud or source for a used one.
Kevin
Old 03-03-2010, 06:16 AM
Those are part numbers for 69, not 68.
Martin
Martin Foltz
68 Camaro SS-396
Old 03-03-2010, 07:37 AM
budnate's Avatar
budnate budnate is offline
email me for some hi res pics , I went digging and found a disc with a few pics of the 68 Nova stick car I parted out a few years ago, I cant recall who got the shroud?...thought it was a member here? shots are so so I was mostly zero'd in on the mint smog system and some of the fan stuff is in the pics.
pretty sure I have the fan and spacer in a box somewhere...where that is exactly is tough,lol.
B
