Old 02-16-2010, 05:15 AM
dave crane dave crane is offline
Default 1968 & 69 427 - 396 Motors & Parts
Selling many 427, 396 and 454 motors and blocks, 1969 427 short block, 4 bolt, steel crank, std bore, it is a 512 casting, the date on the block is G-2-9. There is no code on the front pad, asking 3000. Also a 512 casting 2 bolt block, date code is K-26-9 it is std bore, asking 1500. Also selling a 1968 427 435 HP short block, it is a 4 bolt also, it is a 439 casting with a date code of F-14-8, code on front pad LR, asking 3500. Also have many heads, 840 castings with date code B-19-9 and B-20-9 they are all done ready to bolt on, asking 1500. also 840 with H-24-7 they need to be done, asking 1500. also, also a set of 291 casting with date of 72 closed chamber, they are all done also, asking 1200. also have 990 and 188 casting heads, many others, the 396 blocks are 854 casting 4 bolt block is B-11-70, it is 30 over, no code on pad, take 1000. also have a 2 bolt block, it is std bore, date L-15-70, asking 400. There is just to much to list, call 352-216-2273
