Old 02-13-2010, 02:44 PM
dlv4540 dlv4540 is offline
Default 1968 396 L78 Block CE & #840 Square Port Heads
1968 396 4 bolt block casting number 3935440 dated F-10-8 with front pad stamped CE871320. The block is a warranty counter exchange motor and perfect for a 1968 camaro, nova or chevelle application. The block is 30 over and has one sleeve installed and has been cleaned, magged and pressure tested. I also have a set of rebuilt 3919840 square port heads dated F-17-8 and F-18-8 and a steel 6223 crankshaft, original 8 inch timing cover and factory oil pan for $3250. 330-770-2517 for any questions and will sell as a whole package or consider parting it out. Can ship this set up as well if you cannot pick it up. I have the paperwork on the machine shop work on the block as well if needed.
Dennis Vugrinovich
